Advice on kitchen work surface. (1 Viewer)
Oct 8, 2014
1,544
4,565
Todmorden
Compactline 143
I'm a newbie and always will be. You never know it all.
When I went to Spain last year I noticed a small amount of water on the work surface from time to time. I thought nothing much about it at first, just put it down to carlessness when using the sink.
Anyway it turned out after we were a month into the holiday the tap was weeping from a gland and running down the back of the tap. On returning I went to the dealer who told me the Tap was covered under warranty but not the subsequent water damage to the work surface. (pictures below) he quoted me 3days labour plus the work surface for the repair.
Needless to say I didn't have it done.
So my question is does anybody know if there is for instance, a specialist who could possibly effect a repair in situe?
Les
DBK
18,029
48,100
Plympton, Devon
PVC, Murvi Morocco
If the worktop is chipboard I don't think it can be repaired, it will have swollen as a result of the leak.
But I would look at the fine print of your warranty. It is consequential damage and may not be expressly covered but the leak might have been there when you bought the MH. It could be expensive to repair so legal advice might be worth taking if the dealer won't budge.
barsteward
Oct 8, 2014
1,544
4,565
Todmorden
Compactline 143
I must admit I thought at the time what if it was the skylight' would the warrantee not cover the water damage.
I did report it to the warranty company whilst away but they just told me to return it to the dealers who are adamant its not covered.
Jul 29, 2013
9,071
18,539
Salisbury
Hymer B678DL A class
since 2011
If the base material is now dry and not swollen out of shape you might get away with cleaning out behind edging strip with a hole saw or file and cleaning out rubbish and dust then squeeze some impact adhesive (Evo-Stik) or similar down in between and press the edging back in place if possible clamping it whilst it sets.
It's a bit fiddly to do but can be effective but important that board is not out of shape or still damp.
barsteward
Oct 8, 2014
1,544
4,565
Todmorden
Compactline 143
Thanks, no the board is neither damp nor swollen in fact it has got worse because of the stresses of the curve. I just wondered if some sort of heat could be applied but its such a tricky shape.
Jul 29, 2013
9,071
18,539
Salisbury
since 2011
Be very careful with heat as if it's Formica or similar it is made to withstand it you could end up doing more damage.
I would firstly see if it will ease back gently into place before attempting anything it usually will move back if it does try my cure failing that you may be able to warm it up with a heat gun or hair dryer but be very careful you don't want to crack or split it.
barsteward
Oct 8, 2014
1,544
4,565
Todmorden
Compactline 143
(y)
scotjimland
2,335
10,108
A Woosh bang
Can it be pressed back just using thumb pressure ?
If so, make a wooden former to fit the curve, then inject two part epoxy adhesive.. and using the former, clamp with a sash clamp .
Aug 18, 2014
23,786
133,731
Lorca,Murcia,Spain
Transit PVC
16 years since restarting
& when you've done all that keep an eye on your new tap because they leak for a pastime. Not unusual for them to leak , brand new straight out of the box. If they don't it won't be long before they do. :cry:
Aug 6, 2013
11,953
16,570
Kendal, Cumbria
Le-Voyageur RX958 Pl
since 1999
I would have thought that to be fit for purpose the tap base seal to the surface and the adhesive used for the edging should be waterproof. The sink and its surrounds are after all in close proximity to water and will, from time to time, get wet. I'd take a firmer line with your dealer.
Jul 29, 2013
9,071
18,539
Salisbury
since 2011
The adhesive probably was waterproof but if water got into the base material for the worktop it just swells up and the adhesive just comes away,the answer would be a waterproof worktop base material.When I used to obstruct work tops with chipboard or any timber any holes and edges would be sealed with a primer before fixing the laminates.
kelv
672
895
leicester
Carthago 145
Being a manufacturer of composit kitchen work tops 3 days labour to replace a worktop seems a bit much looking at the photos I am sure it can be repaired take it to a good local kitchen company who make there own units and they will have all the kit to repair the delaminated edge should not take longer than an hour
Aug 6, 2013
11,953
16,570
Kendal, Cumbria
since 1999
Agreed - my point is that the method of assembly should prevent water getting into the base material seeing as it will spend its life very close to, and occasionally covered in, water.
Wickolad
490
542
Wickersley
Newbie to MH, 20yrs+ Caravanning.
My thoughts exactly, in this day and age of recycled plastics I would have thought a recycled plastic Medium density light weight board with laminated finish would be the ideal worktop. No swelling, warping or delamination. But would that mean a drop in replacement worktop sales.
Jim has the perfect solution to the repair, I would also heat the edging strip with a hairdryer to improve workability.
funflair
19,363
30,276
Guisborough
MORELO palace
since 2012
The edging looks like a plastic as its quite thick, it would originally be applied hot so no problem warming it up a bit, the adhesive will be a heat sensitive tape on the back which you can see where it has pulled away. Warm it up and press it back but if it won't stay you will need the contact adhesive route.
It could well be the extra heat in Spain rather than any water that has made it pull away, plastic shrinks over time and the inside corners pull way like that.
Martin
