Advice Needed please 0v on hab (1 Viewer)
carl65
719
161
North Shields Tyne & Wear
This year my van has been plugged in through my home, and heating on low to keep the winter away, any way yesterday we were going away for the weekend, unplugged my van and got things ready to go to the lakes, only to find by two 110v hab battery's are flat according to display says 0 volts ????
I went away just for the day, thinking they will charge up came back late last night after 150 mile round trip still 0 volts both battery's I bought from show last year so new less than 12 months old and have been plugged in via mails source to keep every thing tip top,
can anyone shed some light on what i can do ? apart from buying two new battery's please
Feb 9, 2008
4,094
5,919
SW Scotland
LP Coachbuilt
Since 2008 after caravanning for 20 years
What make of van? Did you have the control panel switched off/isolated when on hook-up?
I charge my batteries week about when standing on the drive and they both keep their charge very well.
Rgds
Bill
imprint
1,087
13
Have you put a volt-meter or multi-meter across the batteries to measure them, or have you just read the control panel? And if so, if the panel itself has a fuse, has that gone which might show the zero readings?
Clearly your van battery is OK. Despite the heating, are the others frozen?
(Senior Partner is on to this one!)
carl65
carl65
719
161
LUNAR ROADSTAR fiat chaise and control panel has been of and on but battery's seem dead
it has been plugged in all the time via mains so should have kept charge be even trip yesterday never put any charge back in ?? that what's confusing me ? (not that takes a lot mind )
sedge
Jul 7, 2009
5,511
13,155
Nr Jct 3 M6
C class
Aug 09 to date 9,000 miles!
So how come your control panel is working then, that must work off one of the batteries, which should surely to goodness be the hab one(s) ?
carl65
carl65
719
161
sedge don't know control panel in say van battery was ok and reading 12.9v but hab reading 0v poor that's the confusing part can both be dead dont have a way of checking them
Wildman
8,470
Ilfracombe, Devon
Amazon Ambassador
since 1967
seems to me there is a two position switch, engine/hab and you have been charging engine, switch to hab and read again.
cobmonster
56
Wokingham, Berkshire
9 years
Hi we also have the roadstar and I have found the vehicle battery goes dead within three weeks, due I assume to the alarm.
I keep an eye on the hab battery and tend to use the charger changing the switch between the batteries through all the time while standing.
I keep an electric covector heater plugged in during winter just above the frost stat level.
When the charger is on the voltage shown on that particular battery indicator flicks .2 or 3 volts continuously.
Tony
lunarman
2,158
2,455
South Glos
since 1994
You say that the panel shows 0v for the habitation battery. You would expect that even a flat battery would have some residual voltage Have you checked that the fuse in the battery feed has not blown?
Lunarman
carl65
carl65
719
161
Lunarman
OHHHH MY GOD what a complete t----r i am checked the fuse it was blown Grrrr :cry::cry:
I cant belive i did not check it Gutted. anyway fixed now.
thanks to all
Squire
324
60
The Lunar Roadstar has the facility to choose which battery to charge - either the starter battery OR the leisure battery. Are you sure you chose to charge the leisure side? Apart from that, I would say it's likely that you have a 'blown' fuse - I think it may be an in-line fuse located on top of the leisure battery.
What year is your Roadstar?
Squire
324
60
Ooops - sorry, I posted before reading that you have already found the blown fuse !! :Blush:
