adria vision
Discussion in 'Adria' started by Larry, Aug 12, 2009.
  1. Larry
    Larry Deleted User
    Does anyone know how to alter the lights for use in europe ?:cry:
  2. JayDee
    JayDee Funster
    Oct 7, 2007
    1,312
    167
    N. Devon
    Can they be altered? I'd always believed you need deflectors. Or have Adria come up with a method?
    John
  3. Larry
    Larry Deleted User
    re adria vision
    the lights are just small circles and deflectors cover them. i have not had a reply from adria. :Doh:
  4. JayDee
    JayDee Funster
    Oct 7, 2007
    1,312
    167
    N. Devon
    Ah! Right! That does make a difference doesn't it:RollEyes:
    I guess your dealer wasn't a lot of help then? Although Adria won't be the only people using that chassis, so why not ask the chassis makers (unless your MH is an A Class in which case the lights will probably not be standard:Doh:)
    John
  5. Larry
    Larry Deleted User
    Lights
    yes its A class. i think its going to be down trying this evening with a piece of board and trial and error. I find it hard to believe that nobody else has this problem!.
  6. Larry
    Larry Deleted User
    vision lights
    Well thanks to Chichester Motorhomes i have an answer to the light problem. If anyone is interested give me a call on 07870533682 and i can talk you through the job. :BigGrin::Rofl1:
  7. JayDee
    JayDee Funster
    Oct 7, 2007
    1,312
    167
    N. Devon
    That's good news :thumb:. Didn't realise the Vision was an A Class.
    John
  8. LesAshmore
    LesAshmore Read Only Funster
    Jan 20, 2009
    283
    40
    Chesterfield, Derbyshire
    To Set Headlights for European Use you need to remove Headlmp surround then you will find screws that will allow your headlamps to be swung outwards on hinges so that you can see the rear of the lamps and ring, at the top of the dip beam lamp you will see a screw that is basically in one side of a slot or in one side of three holes side by side, You need to remove that screw, This will allow your headlamp to be twisted so that you can fit the screw in the other hole ie if in left one change to right one, once in replace all items removed and refitt headlamps.
  9. Maddie
    Maddie Read Only Funster
    Nov 19, 2007
    252
    14
    Ashford, Middlesex
    Blimey, that has left me out of breath reading it :Rofl1:
    Just don't bother !!
    Maddie
Similar Threads
  1. Lunnie
    14
    365
  2. pops
    305
