Adria matrix body (1 Viewer)
Wingingit#1
658
1,742
Adria
Does anyone know what the body is clad with ? Is it aluminium maybe?
How would i go about any dents out of this ?
Thanks in advance .
Apr 30, 2018
1,994
4,425
Mid Suffolk
Adria Matrix 670DC
Motorhoming since 2018.
I'm sure its a composite panel with an aluminium outer. depending on the size of the dent will determine the level of repair. A full repair i.e. filler etc. or a small dent could be repaired by the mobile guys using suction pads.
rog-m740
5
8
If your Adria is white then the 'Comprex' composite wall panel has a polyester outer skin (GRP with white gelcoat).
If it is a silver Supreme model then the Comprex outer skin is painted aluminium.
Feb 23, 2021
1,004
1,565
BURY ST. EDMUNDS
Adria Coral 670 SLT
Since 2002
That's correct and it's very expensive to remove dents. I've had two quotes to remove a dent caused (believe it or not) by a sparrowhawk at full dive speed hitting the back when trying to catch sparrows perched on the rear rail! Traditional panel repair man said, not possible. Plastic mobile repair man quoted £500 with no guarantee of success. So the dent remains.
W
Wingingit#1
658
1,742
Adria
What is 'painted aluminium' ? :unsure:
and i'll have to google comprex cuz i've bever heard of it .
Lenny HB
53,497
150,323
On the coast in West Sussex
Hymer B678 DL
You can't do that on a bonded aluminium panel which the Adrian is.
It pulls the aluminium off of the insulation it's bonded to also aluminium stretches, you can only do that type of repair on steel.
If its a small amount of damage you can fill and spray for large damaged areas they glue a new panel on top of the exsisting one.
W
Wingingit#1
658
1,742
Adria
Thanks for all replies (y)
Theyre only small so if its awfully involved then they'll be staying .
Would you believe aluminium skin with paint on.
:LOL: .....what a donut! I completely misinterpreted that to mean ultra fine aluminium that is applied by spraying it on .....ok i realise how stupid i sound now 🙄.
Apr 20, 2020
1,076
2,355
Northern Ireland.
Adria Compact SC.
Since 2017
Ours is white and is polyester.
The white option appears to be no longer available.
I always thought polyester was better but when there was a choice of white or silver, the silver was more expensive.
Apr 30, 2018
1,994
4,425
Mid Suffolk
Adria Matrix 670DC
Sounds expensive.
Apr 13, 2023
410
327
Staffordshire
ADRIA MATRIX 600SL
1st timer since Jan 2023
Here's the piece I cut out of my Adria Matrix to fit outside shower if you're Interested see how your's made up wingingit. Have asked my dent man see if any possibility of suckering out a dent, and he said theres no way with construction of material's used !
