Adding external GPS module to an iPad (1 Viewer)
RichD1
5
Weymouth
Since 2012
Has anyone added an external bluetooth GPS module like the Garmin GLO or Bad Elf to a standard non-cellular iPad so that you can use it as a sat nav?
If so, which module do you use and is it reliable or does it keep dropping out?
Richard
Hellski
989
2,972
Cheltenham
N+B Arto 76 LE
Garmin GLO, perfect if you already own an IPad without a SIM card. Personally been using this setup for the last 12 months and found it to be exceptionally reliable(y)
Clive
1,296
1,782
Canvey Island
I've been using the Garmin GLO for the last 3 years. Works perfectly. Also found that once the IPad knows where it is you can turn it off. Spent two months at La Manga, only used it for the first day. (y)
Lenny HB
53,448
150,064
On the coast in West Sussex
Hymer B678 DL
We use a Bluetooth GPS receiver with windows laptop, they all work to the same standard so don't see why it shouldn't work.
RichD1
RichD1
5
Weymouth
Since 2012
Thanks everyone, we have an iPad and a mini both without cellular so was hoping that it would work to avoid any further expense.
Richard
Mar 10, 2016
558
617
Scotland
A Class RMB 750HE
Three years and counting, 30 years a tent tower.
What app do you find best with the Garmin GLO? Does the app handle MH sizing?
May 31, 2015
11,684
44,533
Cornwall
Ducato PVC
Getting Better
I use mine through the HUAWEI MIFI and it works a treat on google maps...
Nov 9, 2015
156
245
North Hampshire
Hymer MC-I B 580
I use a Bad Elf GPS with lightning connector. Tried the Bluetooth version first but found it kept dropping out. The facility to still connect the USB power supply through the GPS module is important because it does run the iPad battery down fairly quickly.
In use I have found it to be very good, it quickly sorts out the satellite connections. I run it for CoPilot which I too find good.
sallylillian
3,944
5,014
Falmouth, Cornwall
Palace Liner 90LO
I run a Garmin Glo but with Android tablets, it will supply Bluetooth up to 5 devices, but I have a 10inch Sony on the driver side and my wife has a 10 inch Samsung, both running CoPilot Truck. The app we run is simply called Bluetooth GPS, but of course its Android, there will be a similar app on apple. The Garmin Glo runs with both the US and the Ruskie satellites so wonderful accuracy, not cheap but simple and used by light aircraft pilots.
