Adaptor for leisure battery (2 Viewers)
Dee Dee
5
houston
none
I just ordered leisure battery 100 Amps and a charge relay for my van. It's not a campervan, mostly work based van. I need the second battery for laptop mostly. Now, what adapter to use to connect the laptop to the battery? Apparently classical inverters are not very efficient as the current has to be transformed twice, from 12V to 220v and back to the laptop input standard. But little do I know. I never tried it before. Another option would be to convert from 12v straight to laptop via a dc to dc converter Is this a better option? I can charge my laptop from the cigar socket so thinking as well about just buying a simplified adaptop for a fiver that will simply take the current from the leads of leisure battery, and to which I can connect my laptop charger. What the best option would be here? Thanks
43,331
49,480
If you can currently (no pun intended) charge the lappy via a fag lighter socket then thats all you need connected to your new battery.
But......using the lappy while charging it will extend the charge time dramatically.
D
Dee Dee
5
houston
none
My bad, I don't have a laptop cig charger. I have one mini usb for my tablet. The tablet can charge, but don't know about laptop.
D
Dee Dee
5
houston
none
yep they are cheap allrighty. I will need to connect it to leisure battery. I can get a cig socket with jumper cables for a few pounds, if that's the most efficient option, or a more sophisticated dc to dc converter. How long do you think the laptop will run on this before depleting the leisure battery? How long does it takes to recharge it back again from alternator with the engine running? It's a standard laptop 15 inch with the input of 3 something Amps or so it says on the tin.
Badknee
7,408
412,858
notloB
Vantage Neo
Living the dream.
The clue is in the name, 100 amp hour. I would imagine there is no such thing as a DC to DC converter but a good idea would be an inline fuse between the battery and the puter.
D
Dee Dee
5
houston
none
something like that. I imagine a laptop car charger is also one.
I want to buy an efficient thing that will transfer power from battery to laptop. I can of course go the hard way and buy junk util I find out the hard way what works best here.
2,338
10,132
3amps is the current when powered from the mains.. not when supplied by a 12v battery ..let me explain..
when calculating the time the battery will last you need to consider the power .. in watts .. check the laptop label.
for example.. an 80 watt laptop powered by a 12v battery uses 80/12 = 6.66 Amps.. call it 7amps
You battery is lets say 85 ah .. with a useful capacity of 45 ah (you don't want to discharge below 50% )
divide 45/7 = 5 hours.
Recharging time from the alternator is difficult to calculate, too many variables.. has to be checked with an amp meter while charging.. but roughly the same time as it took to discharge..
Back to your question.. John and Brian both provided the solution.. an , you can remove the cigarette lighter plug and fit crocodile clips, preferably insulated ones, and if required a longer lead.. and clip onto the battery posts
you may have to screw a self tapping screw into the battery post to get a place for the croc clip to attach .. or use a full size quick release battery clamps
if you do this remember to fit a fuse near the battery end of the cable..
2,338
10,132
ooops.. should have been 6.5 hours.. doh
no matter you got my drift
D
Dee Dee
5
houston
none
thanks guys, I'll do just that, the clamps look alright. A bit disappointing how much power it can transfer in a session. I think 80 Watts or as it is case of my laptop 90W is the max power a laptop will use with the cpu going at full blast all the time, which hardly ever happens. I hoped to get at least 12 hours from 100 Amp battery.
43,331
49,480
I hope it isnt 3amps at mains voltage Jim.......thats 690watts.
It will be 3amps from the chargers 19 volt output which is just 57 watts
2,338
10,132
indeed John.. my mistake..
however in my explanation I did say to calculate the amps when supplied from the 12v battery had to be made using the wattage on the label of the laptop.. and not what was on the mains power adapter
32,661
66,573
Perhaps another option would be to look at getting a second battery for your laptop to supplement it's power range that way? You could then recharge them both at home and this could give you an extra couple or so hours, so maybe 4 hours in total for the laptop batteries - although this will depend on the efficiency of the laptop itself! Using 2 laptop batteries and your leisure battery, you won't get 12 hours but you might get near 10 if used carefully (ie by tweaking your power usage, lowering screen brightness etc). As for recharging your leisure battery itself it on the run, how long is a bit of string! It will depend on how much draw you are making for other things, like lights, wipers, radio etc, how far you travel. The only way to keep it charges would be to plug it in to the mains overnight at home.
