Accessing those distant electric points (8 Viewers)
32,661
66,573
Also make sure you've got a way of securing it otherwise it will go walkies! Oh, and the neighbours will be able to tap into the electric too ...:D
Nov 6, 2013
1,416
3,170
S. Ayrshire
The usual
Since the beginning
I'll leave it to the resident Electrical Engineering Consultants to explain why it shouldn't be used.
D
deleted-member02
Bet you still run short !
Ignoring the inevitable naysayers, it looks like a very handle reel to have in the van (y)
23,836
72,505
Nice one.. We have four standard EHU leads. Two at 25 metres and two at 15 metres
Once, in Hungary, we had to use them all.. And I still had yo move the van a bit to get plugged in !
The voltage was not so much delivered at the van as crawled in and dribbled out the end of the cable LOL !!
Sep 24, 2013
1,309
748
Norwich
Carthago A class
Since 2014
Just because it's only 1.5sq. mm doesn't mean it can't be used. I have that size as well as a 2.5 sq.mm cable. Just have to be careful about the load. Still loads of cable to reel in as it should not be used coiled on the drum. But then it does highlight the reduced coiled current capacity in the ad
eddie
8,157
41,271
Taunton Somerset
RV
since 1989
Not so cheap when you consider it is 1.5sq.mm
Also a drum takes up a lot of space in comparison to a couple of 25m cables which we more flexible
2,338
10,130
Just for information.. something to mull over.. popcorn has ran out, BRB :LOL:
Size of cable required for
A 3kw load with a cable length of 40 mt
Required Cable Size 2.5 mm
Voltage Drop 7.83 Volts.
Percentage Drop 3.4%
Current Load 13.0 Amps
Max Cable Load* 25.8 Amps
The same calculation with a 1kw load
Required Cable Size 1.5 mm
Voltage Drop 4.35 Volts.
Percentage Drop 1.9%
Current Load 4.35 Amps
Max Cable Load* 18.5 Amps
17,630
43,340
fit a hook on the trailing end and you could use it for fishing :reel:
Feb 16, 2013
19,735
52,041
uttoxeter
ambulance conversion
50 years
Oh so wrong in so many ways and yet how many French ,Germans and Dutch, do you see with one of these. Piggy backed off one ourselves in Italy , about four years ago.
32,661
66,573
If you want to use the 'full' load capacity you'll have to unroll it totally ... then roll it all back up again ... could take a while but would certainly develop your arm muscles ... 40m is a LOT of winding! You'll end up with biceps like Popeye!!! :D
FJmike
FJmike
972
1,046
Swindon
over ten years
But much easier than untangling two 25mtr cables :)
32,661
66,573
.... I thought that was how you bred 'more' cables ....:LOL:
