Absolute beginner
Discussion in 'Introduce Yourself' started by Tyro, May 31, 2013.
  1. Tyro
    Tyro Read Only Funster
    May 31, 2013
    east yorkshire
    Hello all, My wife and I have just bought an ancient Fiat Ducato Fanfare motorhome and now realise how little we know about it ! For instance, has the ignition to remain on when you are on site, as nothing works without it? I told you we were absolute beginners!Thanks
  2. GJH
    GJH Funster Life Member
    Aug 20, 2007
    27,348
    34,936
    :welcomefunster:
    Ignition definitely shouldn't be on whilst you are pitched. The 12v circuit to the fridge (assuming it has one) should only work when the engine is running, as it would soon flatten a battery otherwise, but all other 12v circuits should work from a separate leisure battery.
    Our son had a similar situation with an old camper van he bought (though it wasn't wired through the ignition). A previous owner had rewired it wrongly so it was taking power from the starter battery. We traced the circuitry and rewired it as necessary.
    I would get the wiring checked out if I were you. Not a hard job if you understand electric circuits and not all that expensive. If you don't understand circuits best get a qualified electrician in.
  3. ukbill
    ukbill Funster
    Nov 3, 2011
    4,929
    4,881
    benidorm
    also make sure your incar electrics are turned on mine is beneath the drivers seat but your maybe elsewhere without this on your 12v wont work but on ehu your 240v will
  4. 4matt
    4matt Read Only Funster
    Jan 15, 2013
    113
    42
    East Riding
    We have a separate consumer unit and charging unit that runs the caravan. You can also charge both batteries from it. What ever you do don't leave your keys in the van and flatten your battery.
    Did you buy Privately? Surly if you did the old owner would have gone through things with you. We got ours from a Dealer and they spent a good two hours with us making sure we understood every detail of operation. They filled the tanks with water showed us how to fill the water heater run through literally everything with us.... We were so impressed by them and they put us at complete ease, so much so we took the van straight to a CL and had a couple of nights away in it.:thumb:
    Anyway welcome to the forum and happy Motorhoming.
  5. f6c
    f6c Funster
    Nov 7, 2010
    3,237
    866
    gloucestershire
    welcome
    Welcome aboard:Wink:
