655 Starline (1 Viewer)
Jul 6, 2023
4
Hymer 655 Starline
New to the group. Previous LMC owner. Buying a 2007 Starline 655. Any advice on pitfalls or underbody corrosion issues? What to look for. Many thanks. Russ
Dec 17, 2016
960
968
Malvern
Hymer B525 2006 A cl
My B525 2006 with the 2.7L is pretty good. Some corrosion on the exhaust so thinking I may replace with stainless at some stage but otherwise it's pretty good for its age. Mine has had extensions fitted to the mud flaps which probably helps. People have had problems with the garage floor rotting from wheel spray but mine is perfect.
Apr 13, 2023
410
327
Staffordshire
ADRIA MATRIX 600SL
1st timer since Jan 2023
Not with my new rear flaps I've just fitted, these are of a 4x4/Commercial type you can cut down to your desired size that work's for your van/moho 🤷‍♂️
Apr 13, 2023
410
327
Staffordshire
ADRIA MATRIX 600SL
Well worth it stops a lot of mud build up and keeps my waste pipe clean, saves keep cleaning it. Ebay approx £15 👌graphics off a trade pal foc then lacquered over to seal them.
As you probably spotted, fronts are genuine oe Fiat as like a snug fit (ocd) lol 😆 Although standard clamps only not enough for me, so I fitted extra self tappers with retainers behind, then painted holes and waxoyled to protect !
Also used double sided black tape between the outer edges to help fill the gap everone moans about 🤣
20230413_122042.jpg 20230413_122031.jpg 20230724_134607.jpg 20230724_134626.jpg
