I'm planning on my first trip abroad to northern Spain next year, is there any issues regarding continental frequencies which I should be aware of when using EHU?
Thanks in advance.
Thanks in advance.
Thanks that has put my mind at rest, I just assumed they were 60Hz
Yes I assumed this was a beginner section where beginners can receive helpful advice from the more experienced without being made to feel intellectually impoverished.
OK, no hard feelings
OK, no hard feelings, apology accepted in full and looking forward to a better start, I must grow a thicker skin. A radiochemist is someone who specialises in gamma spectroscopy to identify radioactive substances.:thumb:
Frequency on board most ships is 60 Hz and I've run all sorts of electronics TV, iron's, kettles ad infinitum over 40+ years with absolutely no problems. Electric clocks tend to gain and domestic tumble driers do not work.
(Electric motors run slightly faster at 60Hz, a tumble drier works with the help of gravity, drum diameter etc allowing clothes to fall off the drum before they reach the top tumbling through the blown warm air. At 60Hz the drum spins faster and the clothes usually stick to it as centrifugal force is stronger hence do not tumble.)
Thought I'd explain before someone asked!
