300watt inverter (1 Viewer)
Jul 13, 2011
287
37
Stoney Stanton
since 2010
I have a 300 watt inverter and want to wire in a plug so that i can use it to charge phones and small items. Is it acceptable to wire in a cigarette lighter socket direct from the leisure battery and if so what thickness of cable do i need? I am also adding a second leisure battery, what thickness of cable do i need for that?
43,329
49,444
Phone charging etc is far better done by a USB socket or a USB adaptor in the cig socket.
In effect what you will be doing is changing 12v to 230v then back to 5v via the plugged in charger or for 12v its back to 12v for other stuff....torches etc. Completely pointless.
Battery cable size depends how far between batteries...the further apart, the heavier the cable.
Next to each other (and using an inverter) I would use a minimum 16mm cable.
One battery under the seat and the other at the back....at least 35mm cable.
AND....unless there is absolutely no possibility of the cable being trapped or damaged ie: next to each other, fit a fuse at BOTH ends of the link cable.
DBK
18,023
48,095
Plympton, Devon
PVC, Murvi Morocco
I would fit a USB socket so you can plug things in directly to charge. You can get double ones, ideally both or at least one being a two amp outlet. If you buy the wire in Halfords it is marked by current, 10A or 15A should be fine. They also sell in-line fuses, and a 5A fuse would be wise but if your USB socket is two 2A outlets then an 8A might be best.
You can wire them directly to the batteries, it isn't very "elegant" and the socket will take a small current drain. If you can find an "Aux" circuit which can be switched off that would be better.
For the extra leisure battery use the same thickness cables as are going to the existing battery. There is a best practice way of connecting the two, you can find wiring diagrams on line, the aim is to ensure both batteries are loaded equally. On which subject if your existing battery is getting on you would be wise to fit two new ones - but I accept that isn't a cheap option.
Edit: PJ beat me to it! I had assumed the second battery would be next to the existing one, if not, much thicker as PJ recommends. :)
Petros
Jul 13, 2011
287
37
Stoney Stanton
since 2010
Thanks very much the info very helpful. Both batteries will be side by side and the existing one is only 15 mths old so i am hoping i don't need to replace that.
Reactions: DBK
Petest
199
185
Uk
New convert
How about something like this. I've wired it into a connector block that was already in the wiring.
Apr 27, 2016
6,872
7,992
Manchester
A class Hymer
Since the 80s
A 300 watt inverter running at its maximum output will draw 300/12 = 25 amps from the 12V supply. Because the voltage conversion is only 90% efficient I'd guess that's more like 28 amps. That is rather too much for a cigarette lighter socket - in my experience most will get hot if passing 15 amps.
Having said that, phone and small battery chargers are unlikely to be using more than 100 watts or so. If you really want a plug and socket you could wire it up with a 10 amp fuse in the cigarette lighter plug, which will let you use 10 x 12 = 120 watts.
Otherwise, wire it up to the leisure battery using a 30 amp fuse, 2.5mm2 flexible cable and a switch that can handle 30 amps. Instead of a switch I'd prefer to use a 30 amp relay and controlled by a small switch. The switch/relay is to cut off the inverter completely. That's because even when off they draw a small current that can drain the leisure batteries if left for a few days, and motorhomes often are. It's a good idea to use an illuminated switch to remind you it's on.
May 8, 2016
1,685
80,895
silver coast, portugal
C Class: Low profile
Boatie for 20 years
Personally I hate invertors. As pointed out above, a 300 watt invertor will draw around 25 amps at full tilt. This entails serious cabling.
I use one of these
Amazon product ASIN B00H5L5VEW
It is what is known as a "buck convertor", draws 15 watts and provides 1.5A at each of the two 5V USB sockets with next to no heat Alternatively one of these will do the job:
Amazon product ASIN B00K4P1HS0
Apr 27, 2016
6,872
7,992
Manchester
A class Hymer
Since the 80s
Yes, I hate inverters too. I have a 4-way and two 2-way cigarette lighter adapters wired to spare fuses in the 12V distribution box from the leisure battery. And that's just in the cab area.
I use two of these:
with the 'backseat passenger extension' stuck on top of the dashboard to power the satnav, tablet, bluetooth GPS unit etc. They will supply up to 2.4 amps per USB socket.
But there are some things that just need an inverter. A gizmo that charges phone batteries out of the phone, that plugs into a wall socket. My CTEK charger to charge the scooter battery. The bluetooth speaker charger with the funny plug that gives 7.5 volts. And even the 120 watt slow cooker that cooks as we are driving along.
I have two inverters, 100 watt and 150 watt pure sine wave, both with cigarette lighter plugs, and I use them frequently. I think the OP would be better off with smaller inverters like these, but if the 300 watt one has already been obtained, then either of my suggestions would get it up and running.
RogueStorm
43
23
East Sussex
Peugeot Boxer Compass 740
Three years, Western West Europe 2015, Eastern West Europe (and some Western East Europe) 2016.
If it's just for mobile phones and stuff I agree with most of the posts above, a simple cigarette lighter with USB socket would do the job. Most rechargeable devices come with a USB and regular three pin charging plug now. If you're looking to run something more power intensive, I had a similar problem with a 300W inverter. My wife is disabled and spends a lot of the time watching the TV when we're away, I also spend time on my laptop for photo editing and such. If I tried to plug them both in to the inverter which was itself plugged into any of the 12v sockets around the van the 'overload' alarm would trip despite the techies in Maplins telling me that the inverter could cope. It's not the inverter that's complaining, more the load from the 12v supplies such as cigarette lighters or dedicated 12v sockets. They then told me to connect it direct to the battery which is Ok but involved opening the bonnet and putting a table in front of the van, which I've done a couple of times, not a problem unless it's raining. I decided to wire a cable direct to the leisure battery and put a socket inside the van. I've used an old three pin, round plug that I had so that no one will attempt to put a regular three pin plug into it. Works like a dream. You would need to keep an eye on the power in your leisure batteries over time but as we're on the road every couple of days this has never been a problem. The cable used was a regular lamp flex with crocodile clips to connect to the battery.
Sep 18, 2015
697
702
Selby, North Yorkshire
Rapido 8066DF
Hi,
I have an Avtex tv and a mod sine wave 300w inverter to run a sat box both plugged into one standard 12v/120w socket split 2 ways possible 8 amp per split and i putting in line a bog standard 12v/25a on off switch to switch it all off in one go, it has run for 4 months like that is that good enough.
any thanks in advance
Bill
