3000w inverter and wiring (1 Viewer)
Nov 30, 2008
87
17
Southampton
Coachbuilt autoroller 700
on and off 20 years
i I have a 300w inverter which I have wired in following JeaN Luc's great description on how to wire an inverter.
I have been given a 3000w inverter and had foolishly assumed I could just swap it over but the cables on the 3000w look huge and I'm wondering if it needs earthing as well. I haven't been given any instructions. My current inverter is less than a metre from my batteryand I would be looking to site this one in the same place as the exisitng inverter.
I also have a 90 watt solar panel which puts a charge back in the battery for when we are running off just the battery.
Any advice would gratefully be taken on board. Rich
scotjimland
2,324
10,061
A Woosh bang
A 3000 watt inverter pulls 250A on full load (3000/12v )
for a 1mt cable run the recommended cable size is 70 sq mm
If the inverter has an earth bolt or connector bond to the van ..
JeanLuc
3,304
2,199
Warwickshire
Hymer B630 Star-Line
As Scotjimland says - proceed with great caution. A number of thoughts:
1. Monster cables required
2. have you sufficient battery capacity? A 3 kw inverter at full belt will flatten 2x110 Ah batteries in a few minutes.
3. You need a relay capable of handling 250 amps plus.
4. A 3 kw inverter will generate some heat - is the proposed location well-ventilated?
5. Do you really need 3 kw capacity or do you just want a bit more than 300W and happen to have this monster available? If so, buy the size you really need - under-running a big inverter is inefficient as they draw a larger quiescent current than you could get away with.
6. If such a large inverter is not installed absolutely correctly, there is a serious risk of creating a fire hazard.
More knowledgable members may post other opinions on this matter, but I would not feel too confident to proceed.
p.s. many thanks for the kind comments in your previous post.
Wildman
8,470
Ilfracombe, Devon
Amazon Ambassador
since 1967
the 3000watt inverter will give you the ability to drain the battery in a few mins literally. If you have no idea how to wire it and sizes to use I would suggest you also don't have the knowledge to save you from cooking the batteries ( how many do you have by the way). Not being funny but 300W is sufficient to run a TV, laptop, chargers etc with a very low sandby power consumption. a 3KW job on the otherhand will consume a few amps even when not being used. Do you really need it. I know it sounds a great idea and some people do have them fitted. But they do require specialist knowledge to use in safety. I would offer to take it off your hands but have no use for such a beast so no axe to grind.:Blush:
aba
2,775
1,112
yorkshire
coachbuilt
dec 2009
if its not a pure sine wave one throw it in the bin or use it as a ground anchor if you get stuck in the mud somewhere.
R
Nov 30, 2008
87
17
Southampton
on and off 20 years
Thanks everyone I think I will stick with what I have this seemed like a good idea as it was a freeby a bit more power would be nice but we have managed as we are and I see no reason to rush into changing what I have. I'll see if I can sell it and split the proceeds with the person who gave it to me.
vwalan
Sep 23, 2008
8,835
5,798
roche cornwall
lynton5th wheel
since a child
hi, not had a 3000w invertor . but use a 2000w inverter almost constant.
it came with two live feeds and two negative feeds . the cable supplied with it.
just connected them into the battery bank.
it stays on most of the time . when away it handles the 240v fridge and various other things .
at home i park next to the house . run an extention lead from the inverter into the house . keeps the fridhge in the house running . when its sunny i plug the big deep freeze from the house in as well.
its just a cheap ring modified sine wave.
yes have more p[anels and a big bank of batteries . the sine wave bit ,i have only found one fridge that it wont work. luckily it was a mates . but i,m happy with it been running it for about 5yrs now. best 139 quid i could have spent.
