2nd time lucky. (1 Viewer)
hedgefordpete
51
29
cannock chase
low line
im a newbie
hi funsters, i am back from a long weekend at the caravan club site in broadway .
the weather was good and my son and his family turned up in his motorhome to spend the weekend with us.
the batteries stayed charged up after the onboard charger had been replaced.
did anything else go wrong? well.............
we couldnot light the gas cooker.
checked everything, all ok. still no gas.
yes, i had turned on the gas bottle, i am not that daft.
in the middle of the night a thought crossed my mind? ha . ha. i hadnot turned on the little yellow tap on the regulator valve.......:Doh:
still learning, regards, pete.:thumb:
jonandshell
5,476
8,299
Norfolk
Not got one!
Since 2006
We've all been there!
At least you found it yourself!
It's much worse when your other half finds the fault and your manly command of your motorhome is cast into serious doubt!!!!::bigsmile:
Road Runner
1,143
1,445
Europe
yes
Since before Motorhomefun
You not the first or the last to make mistakes, I sure have................:ROFLMAO:
Glad things went fairly smoothly......
Jaws
23,836
72,493
Thetford Norfolk
C class, Chieftain
since 2006 ( I think ! )
All the things you learn as you go is what makes MH whatr it is !
I would have been bored and sort other things to do if it was not for the constant learning curve we are all on ! :thumb:
Popeye
Sep 5, 2011
7,926
86,461
edge of New Forest
Frankia Platin Plus
On and off since 1983
in the middle of the night a thought crossed my mind? ha . ha. i hadnot turned on the [HI]little yellow tap on the regulator [/HI]valve.......:Doh:
Both times it has happened to me was exactly that, you're not alone...Griff:thumb:
