240V Circuit Breaker Problem (1 Viewer)
Hymerjo
5
Staffordshire
Have a CHNT NB1-63 240V circuit breaker fitted on my Hymer 655. It fails to reset when switched on/off yet display unit over the door shows 240v connected. None of the 240v sockets are live. Is there a fuse in reset mechanism in the breaker or does it mean a new unit?
scotjimland
2,324
10,065
A Woosh bang
No fuse in an MCB .. have you pushed it off to reset ?
Does it trip or just not reset ?
If so, then it may be a faulty breaker..
43,329
49,444
as Jim said, some breakers require you to push down before resetting upwards.
try resetting with the hookup lead unplugged...if it resets OK then you probably have a fault on the circuit...faulty appliance, mouse chewed wiring etc.
if it wont reset with power off you have a knackered breaker and it needs replacing.
suitable replacement
(the pic shows a 16a)
Sep 27, 2007
837
289
Shropshire based
Globecar
started in 2001
We had the same problem, only last week, unpluged the EHU and re pluged, and all was well.
Hope it works for you:thumb:
