2012 x250 ducato air con fuses and relay
Discussion in 'Fiat' started by rutteger, Aug 15, 2016.
  1. rutteger
    rutteger Funster
    Feb 4, 2016
    43
    4
    Midlands
    Can someone advise as to which are the fuses and relay for the a/c in a 2012 eu5 (i.e. Facelift) ducato 130. Currently in the south of France without the handbook and with the a/c having stopped operating.
  2. Bill_OR
    Bill_OR Funster
    Dec 11, 2011
    481
    619
    Nr Hastings, East Sussex
    According to the Fiat manual the A/C compressor is fuse F19 (7.5A) in the fusebox under the bonnet Capture.JPG
  3. SandraL
    SandraL Funster
    Jan 24, 2012
    287
    153
    Somerset
    If the pressure in the aircon is low the system will not run. When ours lost its gas the radiator fan would run for about half a second when turning on the aircon with engine already running. Most garages will regas the aircon, if thats required make sure they add some uv dye to the system so that leaks are easier to find next time. Cost to regas varies fron £30 to £60 ish. They should not regas if there is a leak which they check for by seeing if the system holds a vacuum.
    I know you asked about fuses but hope this is of some help.
  4. rutteger
    rutteger Funster
    Feb 4, 2016
    43
    4
    Midlands
    Thanks for the info. Suspect it is indeed lack of gas (although it worked at the start of the trip), worth checking the fuse and relay anyhow.
