2 TV's?? (1 Viewer)
Aug 13, 2009
49
22
KENT
Caravanning since 1990's Went over to motorhoming 2007
I have a fold-down tv at the front of my Scout and a portable tv at the back...does anyone know how different programmes can be watched at the same time? Do I need 2 aerials?
I've had to suffer a wet & cold weekend away and had to watched kids programmes & constant arguing......never again!!! :cry:
DP+JAY
2,536
14,785
Dalbeattie
Laika 5009
since 2007, 25 years tuggin before that.
If they both have freeview no problem. If not you need 2 freeview tuners.
43,392
49,865
as Brian said....a simple splitter then a seperate coax to both TV's.
Broken Link Removed
if you use a sat box and dish then you will need a second box for one of the TV's and a dual LNB for the dish
MikeD
3,936
3,697
London
IH PVC
Since 2012
autotrail sound system
Sorry to hear about the wet weekend and grumpy kids but no matter what you do the watchers of the rear tele will always hear the sound from the front tele as the autotrail sound speakers for this tele are also in the back.:cry:
raysalaugh
2,289
4,207
Leyland
AT Delaware
since 2010
2 tv's
I have a Avtex tv in the rear lounge which has freeview, I can watch any channel available and still watch a different program on the dropdown telly at the front which has its own digibox next to the Sargent control box.
So only one aeriel required, but two digital sources.
regards
Ray
kev&caz
Aug 13, 2009
49
22
KENT
:cry::Sad::cry:!!!!!!!!!!!!!!!!!!!!!
tonka
10,850
21,563
Cannock, Staffs
A class Burstner 800
Since 2000
Kev4caz.
What year scout ?? pre 2006 ??
If it is you will maybe have a Humax freeview receiver sat in the cupboard by the power supply unit.. Let me know if thats the same set up and I can explain further...
43,392
49,865
the speaker wires were put in, so can be taken out....or disconnected in this case.....only got to pull/cut/de-solder the connections off the rear speakers :winky:
tonka
10,850
21,563
Cannock, Staffs
Since 2000
Regarding the rear speaker thing..
You only have to go into the radio setup and turn the volume to zero for the rear..
Simples..... No cutting, no solder and you can turn it back on when you want..
You will have a setting for left and right balance PLUS front and rear balance... !!!!
Geo
Trader - Funster
Jul 29, 2007
11,757
14,565
Mansfield,Notts
Autotrail Tracker FB
45 +years with breaks
After youve sorted out the channel problems
Wireless headphones for the odd man out:thumb:
Transmiter simply plugs into whichever TV you want to hear and bobs yer auntie
G
kev&caz
Aug 13, 2009
49
22
KENT
Kev4caz.
Thanks Tonka but it's a late 2009 model and there isn't a Humax freeview receiver in the cupboard. :Sad:
tonka
10,850
21,563
Cannock, Staffs
Since 2000
AH... Stuck in the middle ground on this one then. I have a 2005 model apache 700 and familiar with that AV setup.. Also a new 2012 version which has a 7" screen in the dash and Tv inrear.
Not sure on the 2009 setup. Can only assume that the cab drop down screen has it's own built in freeview receiver and the TV is the same. that being the case I cant see why you would not be able to tune in seperate signals..
Regarding audio,If your TV is an Avtex, they have a transmitter that sends a signal to the cab radio for broadcast. May be worth checking the handbook / menu's as this can be de-activated.
