1990 Ducato Won't Start After Fitting Wing Mounted Ariel (1 Viewer)
Mick T
Leeds
Fiat Ducati
1 yeat
Hi everyone,
Can anyone shed some light on this for me.
I have a 2.0 Diesel 1990 Fiat Ducato and yesterday have replaced the wing mounted radio Ariel on the O/S wing, in order to do this I have had to take the wiper motor off its mountings to gain access, put it back together and the camper won't start.
May be worth mentioning that it has had an engine and gearbox conversion to a later model with dash mounted gear change. On the plus side the radio works now, on the downside, we've had to cancel our weekend in Whitby.
Mick T.
MikeD
3,936
3,697
London
IH PVC
Since 2012
welcome to the fun Mick
but sorry I can't help but will bump your post up to the top again. (y)
Nov 18, 2011
11,862
43,028
Planet Earth
A van
Over 25 year's
check the fused link there may be more than on dose it turn over or is it dead
did you disconnect the battery before caring out the work
bill
M
Mick T
Leeds
Fiat Ducati
1 yeat
Thanks Bill will try that as I didn't disconnect the battery, fuses in glove box ok though
davejen
1,861
1,235
Preston
Given up travelling
Since 1992
I would imagine you have accidentally knocked a wire off somewhere, it might be an idea to re-do everything you have done and check for a loose wire. Just an idea.......
Cheers, Dave(y)
dave newell
3,262
4,369
Telford, Shropshire
Home converted PVC
26yrs
We need more information:
Does it turn over on the starter but won't fire or not turn over at all?
Exactly which engine and gearbox is fitted and what year is the power unit from?
Who did the power plant conversion?
D.
Nov 18, 2011
11,862
43,028
Planet Earth
A van
Over 25 year's
if it turns over but wont start try tracing the earth wires check that all the weirs are on the earth tags there should be one very near to the wiper motor on the inner bulk head it could well be a earth fault clean up your earth tags you might have moved it giving you a bad connection
check you haven't dislodged a wire to ignition loom check you are getting power to fuel pump if its turning over but not starting
and the ÂŁ10 subs will be the best tenner you will ever spend
bill
D
Deleted member 29692
If the cab electrics work but it won't start have you somehow disturbed the starter motor earth strap?
TerryL
6,187
8,189
North East
Low Profile
Seem to remember a thread some time ago where the windscreen wiper motor damaged, or at least disturbed, some wiring related to the starter - not enough slack or something similar. As you've had the motor off I would check carefully for any loose wiring or connector blocks in that area.
