14" or 16" (1 Viewer)
wildcamper
3
Merseyside
High Top
wheels that is :roflmto:
I have a Talbot Express 1.9 diesel on 14" wheels, would there be any benefits to changing to 16" wheels ???
Would it cruise better, better mpg, etc
Look forward to any advice :thumb:
derekfaeberwick
1,035
9
Berwick
Low Profile
9 Years
You could end up being too highly geared and your speedo would need recalibrating. Tyres would cost more as well. Lots of pain for little or no gain unless you are getting the wheels and tyres free. :Sad:
43,331
49,467
16" wheels would be absolutely fine if you fit ultra low profile tyres.........maybe a '40' profile or less.
very little difference in fuel economy, gearing, speed as the tyre radius will be around the same as a 14"
the only problem you would encounter is finding low pro's to suit your vans weight rating.
you aint gonna find any though.:Doh:
if you fit standard 16" tyres you will never get out of third gear:winky:
derekfaeberwick
1,035
9
Berwick
Low Profile
9 Years
You say it soooo much better than I do! :winky::ROFLMAO::ROFLMAO::ROFLMAO:
bob
47
7
ALDRIDGE WEST MIDS
rapido
SINCE 1992
Hymer on 15inch wheels
hithe
Would I encounter similair problems changing from 15 to 16 inch wheels
the problem with the hymer is the ground clearance the chasiss catchs speed bumps sharp inclines like when you come off forecourts ferry ramps we have even recently had the tailpipe off when rallying on a field which a nice RAC man replaced at the same time saying they would not attempt a recovery because of the insuffiecent ground clearence and they would not clear the recovery vehicle base. I know that some models which are the same as ours are fitted with 16 inch wheels but it might be something to do with the weight as they were 3850k and ours is 3500k. We been Quoted £1500 for new wheels and tyres But we can source for around £900 and between £1500 and £5000 for air suspension at the moment we are still thinking about it.
derekfaeberwick
1,035
9
Berwick
Low Profile
9 Years
hithe
You would gain an inch of clearance at the very best. £1.500 ? Ya pays yer money and takes yer chances! :Sad:
derekfaeberwick
1,035
9
Berwick
Low Profile
9 Years
Plus tyres Pappa. Not being picky but the 1" is only the rim and with new tyres? A change of tyres on a truck can gain op to about 2 M.P.H. at 55. Sorry to be so pedantic, either way it ain't worth the money. :cry:
bigdubber
4
wirral
a
i had 16" wheels running on my talbot merlin 2ltr petrol and it was fine cruising .it did slow down on the hills but it did that anyway on the 14" wheels.
my mpg was improved slightly and an increase of around 5 mph cruising speed.
