12v socket (1 Viewer)
irnbru
13,514
31,142
Glasgow
Benimar 264
11 yrs
Is a 12 v socket easy to rig up? is it a case of buying a cigarette socket with a positive and negative wired to leisure battery.. Just guessing? Or is anyone around Glasgow that can guide me on MUST HAVES?
GJH
29,450
38,827
None, now sold
2006 to 2022
Basically, yes. The main things to ensure are that proper (car, not domestic) cable is used (17 amp rated is what I've used in the past), you have an in line 10 amp fuse, you lead the cable through a route where it won't get tramped on in normal use and you mount the socket in such a manner that the connections will remain safe.
TheBig1
17,630
43,278
one of these kits contains all the essential parts you will need. if the wire is not long enough just add some more. basically though its red to positive and black negative terminal on your battery
Link Removed
G8WVW
92
67
Cumbria
C class
Since 1990 on/off
I fitted a couple easy enough to do but I only fit 3 amp fuses as we only use them for phones and such
Good call ... cigarette lighter sockets are electrically and mechanically RUBBISH!
How many times have you had to wiggle the phone charger to get a good connection! When car manufacturers say 10A/120W in the handbook, what they mean is that the wiring is good for that not the socket!!
43,329
49,445
beware of the multi outlet adaptors.
I have melted two at less than the faglighter sockets stated 10amp max load.
On looking at the twin outlet adaptor it states 5amp max combined load.....not something you expect when it's designed to plug into a 10amp/15amp supply
