12v power supply (2 Viewers)
ShiftZZ
21,383
84,583
Dark Side of the Moon
We have Dell laptops, and I have a 12v kit that allows me to power the laptop from teh 12v supply. Mrs ShiftZZ has an Inspiron m 301z and that ddoes not like the 12v supply...
Does anyone know of an alternative for the Inspiron?
cbrookson
398
436
Suffolk
Le Voyageur RX9 2012
Since 2001
Worth checking to see if the £19.99 Link Removed will work with the Dell you have?
Cheers
makems
3,440
27,713
Ingleby Barwick,,Teesside
Sadly had to give up
Double check that the 12V adaptor is powerful enough.
I've ahd the same problem as my Wife and I had different laptops with similar looking chargers. When mine wouldn't charge up I found it was because we'd somehow mixed up the adaptors and my Wife's wasn't powerful enough.
Some Dell laptops are much more power hungry than others - some require AC adaptors of 100W. If your 12V adaptor doesn't put out enough juice it won't charge.
Apr 22, 2013
911
661
Cotswolds
Bailey Approach 625
Since 2011
This one looks to do the job
[ame="http://www.amazon.co.uk/gp/product/B004OQPF88/ref=pd_lpo_k2_dp_sr_2?pf_rd_p=103612307&pf_rd_s=lpo-top-stripe&pf_rd_t=201&pf_rd_i=B006SZMEF0&pf_rd_m=A3P5ROKL5A1OLE&pf_rd_r=02CEES4202DE071XDB22"]Power Supply - Car Cord - Car Adapter Charger for Laptop/Notebook compatible with model: DELL INSPIRON M301Z N5010: Amazon.co.uk: Computers & Accessories[/ame]
Gordon
17,635
43,362
another solution is a cheap 150w inverter and use the mains power supply
11,843
14,080
My latitude needs a 90-100w adaptor, though runs fine from inverter, however noting post above, it needs a cheap 500w inverter as the 150w would not be up to the job. (power supply rated at 1.5A at 230v ie 345w)
23,836
72,540
JEEEZZZZZZZZZZZ !!!!!!!!!!!!!!!!!!!
How much current are those lappys drawing for goodness sake ?
Have a look at your battery
See what the Ah rating is..
Then fire it up on the battery and see how long it lasts.. Not VERY scientific but it will give a far better idea than just going by what is printed on a PSU that is proly used on countless different things and is over rated for a good many ..
scally
1,145
8,516
essex and lincolnshire
Eldiss Autoquest 320
since 1998
not to frighten the life out of anyone but I watched a tv prog the other night that showed how many cheap lappy chargers caught light:Sad::Sad::Sad:
only sayin......................:thumb:
17,635
43,362
a friend of mine bought a cheap charger from a chinese guy on Ebay. within weeks, the casing fell apart exposing bare wires because it got so hot and expanded/contracted in use. they asked me what was the best glue to repair it and were surprised when i said to bin it
buy cheap and nasty and you get what you pay for. buy from a good seller with good feedback and offering a long warranty. it may cost more but gives peace of mind
17,635
43,362
forgot to say, the chargers are nearly all made in china now, but theres a difference between original specification and a cheap copy. check for a genuine ce mark
GJH
29,450
38,827
None, now sold
2006 to 2022
[HI]
Does anyone know of an alternative for the Inspiron?[/HI]
Acer, HP, Compaq, More or less anything :ROFLMAO::ROFLMAO:
11,843
14,080
True, but running off its battery it draws around 28watts, but connected to the mains it is charging the battery and running the laptop, so chuck in a bit for inefficiencies and a bit of safety margin and I don't think it would be a lot less than the 90w stated. :thumb:
