12v fridge question (1 Viewer)
Mags52
1,433
1,731
Melrose Scottish Borders
Hymer B774
Since 2010
I'm not sure that our fridge is working on 12v when we're driving. We've been in France and Spain for 9 weeks and every time we drive for any length of time there is water in the fridge when we stop and the frozen stuff seems to have defrosted slightly. It's an Autotrail with automatic switch over and it is showing battery on the fridge display when the engine is running. At the start of our trip I thought it was the warm weather but it's very cold now and the water is still there after a run. It's still under dealer warranty. How can I check that it's working? It's going back in for a couple of other problems so I can ask them to check but I'd like to know for sure.
Mags
Dec 6, 2011
11,589
25,418
South Wales
Coach built Adria
if things are defrosting it cannot be working properly. so i would tell the dealer it dont keep down to temperature on 12v and get them to check it out.
then if i were you i would check its keeping its temp after they say its fixed.
Cleve
789
2,333
France
Hymer 654
Does your fridge have the big vents on the MH wall which require the winterisation below a certain temperature. They simply clip on with a single lock on each using a quarter turn.
I had the reverse problem of it not staying cold when I was driving South in France, consistent temperatures in the high twenties.
Finally and under duress (being a bloke) I read the instructions - doh, took the panels off, very simple and popped them safely in an overhead locker.
This may help, I hope it does.
The other thing I learned - having finally succumbed to reading instructions - was the reason the gas boiler which worked perfect on electric but just would not play on gas was because I had not removed the exterior vent cover. Yes - doh again!
It is becoming easier to read the instructions now.....
JeanLuc
3,304
2,199
Warwickshire
Hymer B630 Star-Line
I have just had the same problem but mine is a manual energy selection fridge. I tested the cooling function by putting a fridge thermometer inside the fridge. I could tell that it was working on gas or mains but the temperature rose once we were travelling. Assuming the fridge is not left open for long, the 12V supply should be able to maintain a low temperature.
My fault turned out to be a poor connection in the 12V line from the Elektroblock to the fridge, caused by arcing at some point in the past and a burnt connector. In your case I would suspect either a blown fuse or a dodgy connection somewhere. Just tell the supplying dealer what the symptoms are and leave it to them to sort out.
Aug 6, 2013
11,953
16,570
Kendal, Cumbria
Le-Voyageur RX958 Pl
since 1999
It could of course be the usual reason: that the OEM wiring is underspecified. I've rarely seen more than 11v at the fridge with the engine running on any motorhome. Decently wired the fridge will freeze its entire contents when on 12v.
