12 volt electrics (1 Viewer)
Theresa100
16
6
Eton
Low profile
10'years
Does anyone know of motorhome electrics service in the berkshire area many thanks theresa
43,331
49,467
there isnt really anything to service on the 12v side.....if a fault develops the fuse blows.
230v mains electric ideally needs checking and testing annually but should be done during a habitation check.
scotjimland
2,335
10,108
A Woosh bang
Correct.. not a lot to service.. mostly checks..
From Habitation check list sheet.. http://www.readcaravans.com/workshop/aws_motorhome_checklist.pdf
Most, if not all can be done by a reasonably competent person ..
12V ELECTRICS
Check that the leisure battery is being charged by the engine and mains charger
Fridge - check operation
Interior lighting & equipment - check operation
Leisure battery - check security, electrolyte level & lubricate terminals
Wiring earths & fuses - inspect condition & correct fuse rating
Electric awning & step - check condition & operation
External socket - check condition & operation
230v Mains.. Different story.. they should be checked by a qualified electrician ..
MAINS ELECTRICS
ADDITIONAL WORK. SERVICE INFORMATION. SAFETY STATEMENT
Inlet plug - inspect
Hook-up cable - check if available
Earth bonding - test
Metal surfaces bonded - check
RCD operation - test
Socket outlets & permanent connections - carry out visual & functional check
Appliances fitted e.g.: air conditioning - check operation
cmcardle75
2,666
3,446
Reading
Riot Van Conversion
Since 2012
It's funny really, because 12V electrics off a lead acid battery are probably more dangerous than 230V electrics. Everyone is scared of the volts, but it is the amps that cause actual fires that actually kill and it is the high currents required by the low voltage that cause those.
It is why the 230V UK gets a fraction of the electrically caused deaths of the 110V USA. Hardly anyone gets electrocuted in either case, but loads get killed by the higher currents that are much harder to protect against because the maximum earth loop current is so much closer to the operating current that fuses and breakers are less effective.
Remember when playing with lead acid batteries that they are much more dangerous than a mains socket.
