x250 under wing panel "HELP"!
South Wales
s
Hi All; had van back from its first mot on Friday. was under the van today checking oil filter etc ready to do an engine oil change.
i noticed there was no plastic panel on the near side between the wheel arch and the bottom of the front skirt.. while there is one on the offside.
called the garage who did the mot thinking they may have taken it off for some obscure reason. no they said! not to do with us.
anyway cant say i have noticed if there was or was not one there before, but it does expose some wiring high up under the front of the arch.
could any of you who have an X250 have a look for me to see if there is a panel between the plastic inner wheel arch and the front skirt please?
thanks in advance for any help
Yes the whole wheel arch is shielded.
Third party replacement example
Broken Link Removed
Thanks Andy, got that bit in place its a flat piece from the bottom of that wing insert to the front skirt. sort of segment shaped i'd guess.
That one doesn't actually look like the genuine one does. They are often on ebay but not just now
ill have another clamber under in the morning but it looks as if there are securing holes so something "appears" to be missing
That may be part of the engine undertray, I guess you haven't got any
Broken Link Removed
looks a bit like this i would guess
BEWARE if buying any to check they come WITH fixings as nearly all do not.
Broken Link Removed
Reactions: f6c
cheers. i just wonder where the original went !!!!!!:mad:
Hi Andy, it never had the center piece but now the nearside segment is missing.
They rely on the centre section for most of their support
ok. there appears to be a supplier on fleabay from Poland who do the full set delivered for £52 just waiting to find out if thats with fixings
