- Jan 11, 2022
- 2,267
- 3,293
- Pilote P732 2011
- 3rd Time around, since 2000
Thanks Michael.I used bus bars simply because I have 2 batteries on ks 200a and one fogstar 280a so needed to get them to work together properly, if I only had 1 battery I would just stack them.
Thanks Lenny HBBus bars if you have two or more batteries make sure the cables from each battery are the same length.
Even if you only have one battery Bus bars makes the wiring far easier.
If your running a decent size inverter, and your lithium batteries have internal BMS's you'll save potential problems using a BUS bar
Connecting multiple Lithiums in the same way as a conventional lead acid set up can cause the initial load requirement from the inverter, which would individually too great for one battery to cope with to cause the battery to shut down, it's impossible to synchronise say three separate batteries to all respond at exactly the same split second and inverter requires power.
Three connected to a BUS bar stops this
If your using a more sophisticated set up with external BMS this can be allowed for in the programming
That looks like a right bodge.Hi Eddie,
This is the image that had seen, single battery but there's a 2000w inverter in the mix.
I thought I had read on here and other sources that it is best practice to use busbars over stacked connections as it removes most of the risk of the main battery connection coming loose and easier to fuse each wire.
Mines all busbars but was just taking the collective knowledge on this.
Regards John
Funny you should say that, bet you would feel better if you had spend 3k getting it fittedThat looks like a right bodge.
If I'd been charged a fiver I'd be doing my nut.Funny you should say that, bet you would feel better if you had spend 3k getting it fitted
And from a well talked about companyIf I'd been charged a fiver I'd be doing my nut.
Name and shame please, dont want others making same mistakesAnd from a well talked about company
Wasn't my install and have no dealings with the company, might be a bit controversial to name themName and shame please, dont want others making same mistakes![]()
Ooh not one that everyone thinks are the only company who can install an alarm by any chanceWasn't my install and have no dealings with the company, might be a bit controversial to name them
