Mysterious Orifice
Simon
Ramsgate, Kent
Swift Kontiki 600
First year under our belt!
I have found a hole hidden away in one of the wall cupboards in our Swift Kontiki! It looks like it should be 12v as a photo reveals metal contacts inside, but it's *slightly* too small for a fag lighter plug and much too big for a Euro plug.
Any ideas?
Much too big for a euro? It looks about the same size as a European 12v socket I swapped on our van. Do you have dimensions?
A euro plug rattles around in it and there's no positive contact at all at the end. I think if I forced it really hard a normal cigar lighter plug would go in, but I doubt it would come out again.
It looks like an addition someone's wired in so I wonder if it's just a badly made socket?
Some euro fag sockets used to be about 1mm smaller than UK.
I wondered if the metal at the end is / was the live. Maybe there was a metal earth collar on the inside that has come out?
If you unscrew the screws and pull it gently out, is it attached to wires? If they are live, you could replace it with a UK ciggy socket.
Thanks for the replies. Problem solved - it's just a crap cigar socket. One of the three plugs I tried went into the socket and one of the other two was *just* too tight so I gave it a medium grunt and the back of the socket gave way.
Wasn't wired in anyway, which was just as well looking at the connections!
Ah, that comes under totally foobard:eek:
