Kip or LG2600 Generator
lesleyjean
I have just placed an ad in classified for a Kipor IG2600 Generator.
I have never used it, the only time it has ever been switched on was when Wilman (Roger) showed me how to turn it on.
I have had a solar panel fitted and we only ever use campsites.
When placing it in classified I thought I was moving to next step and pressed enter and the ad was placed. I do not know how to edit it and put contact details on it. :Doh:
If anyone is interested pm me. I think £375 is a very good price. I could take it to Roger's meet.
Lesley
are you sure its an LG2600 AND NOT IG 2600?
is it yellow?
Sorry, yes it's an Ig 2600:
And yes, it is yellow:BigGrin:
thats a good price as they are £470 plus new:thumb:
i dont need one but if i did i would have been intrested?
the full specs are as follow's
PURE SIGNWAVE PETROL GENNIE
Rated frequency (Hz) 50 60
Rated voltage(V) 230 Rated current (A) 10 19.9.6
Rated speed(r/min) 3600
Rated output (kVA) 2.3 Max. output (kVA)
2.6 DC output 12V-8.3A
Phase number Single Current circuit breaker Without Structural type
Portable Fuel capacity[FONT=宋体]([/FONT]L[FONT=宋体])[/FONT] 4.8
Set fuel consumption[FONT=宋体]([/FONT]g/kW.h[FONT=宋体])[/FONT] 500
Continuous running time (hr) (rated output) 3.3
Noise level (zero load--full load) dB (A)/7m
63-72 Overall dimension(L×W×H)[FONT=宋体]([/FONT]mm) 564×317×453(genset)
Net weight[FONT=宋体]([/FONT]kg[FONT=宋体])[/FONT] 26
Starting system Recoil starter
Fuel type Automotive unlead gasoline
Lube oil type SAE10W30 (above CC grade)
Engine model special for digital generator
Engine type Single cylinder, 4-stroke, OHC,gasoline
engine
Bore X Stroke 66X50 Displacement(ml) 171 Compression ratio 8.5 Rated power[kW(Hp)/(r/min) 3.3/3600
Ignition system T.C.I Spark plug -F6RTC/WR7DC
Lowest fuel consumption[FONT=宋体]([/FONT]g/kW.h[FONT=宋体])[/FONT] 395
When we fultimed with the van for 3 years before we retired we used a kipor IG 2600, gave us plenty of power, enough to run most electrical things and not noisy.
I've got one, does the job, but definately inferior in quality to a Honda, but HUGE price difference reflecting this. Just keep an eye on it keeping vulnerable parts lubricated to prevent rust, the nuts holding on the feet can work loose, if they do it requires the chassis being removed to get to the inner nuts, it was only after this exercise I found the start of rust.
Please note that I do take mine on my boat occasionally so it is exposed to sea air, but that is only occasionally on long wild boating Channel Island trips :thumb:
kip Genny
Im very interested in generator if you have not already sold
Chris
(base in N. Devon):thumb:
Chris
Hi Chris
Still for sale if interested. :thumb:
If you are I will pm you my address and you can take a look
Lesley
