Ford Transit based MH - Injector Protectors
TGL
Bailey Adamo 75 2025
If you were wondering how effective these rain water dispersal / injector protectors are, I would personally say "very". I have a brand new Ford based Bailey Adamo and it rained on Saturday. I thought I would check the protector and it had quite a bit of water in it. The MH was on a slope, so the water collected away from the drain hole on the other side. I only purchased the protector, because a friend with an older Ford Transit based MH had to pay over £600 to get his injectors drilled out and re-installed. They were locked solid due to corrosion. The £140 I paid for the protector will be worth the money in my experience. I've realised the rain water is seeping through the edge of a plastic sill (See red line in pic of the join area) that sits just below the windscreen. The water runs down the arm of the windscreen wiper (shown in the attached pic).
I suppose the alternative is to remove the windscreen wiper arms and then the sill to put mastic between the plastic and the windscreen, although the water would then no doubt find its way into another part of the engine bay and down somewhere else where there are electrical bits that would be damaged.
They're probably well worth it if your van is parked for extended periods or you don't have a screen cover on whenever it is parked. Silly Ford design in the first place !
Reactions: TGL
Can you provide link to where they can be purchased please?
Reactions: TGL
This is the one I purchased: eBay Injector Link
Note that it's a little bit fiddly, but easy when you know how to install it. I put the supplied hose on the tray first with the jubilee clip. Then I mounted the bar for the underside mounting clamp with one of the supplied screws (the left-hand side of the clamp. I turned the screw so it was just on the thread. Then I carefully manoeuvred the tray and the bar so it slipped under the plastic mount point on top of the engine. Finally I put the second screw in on the right-hand side. A little fiddly, but only took me about 15 minutes tops.
I have it on good authority that the Mrk 10 Ford Transit (when it eventually is released) will resolve this issue. Shame Ford won't retrofit a solution.
