Fitting gas connector to hose
Heybrook Bay, Plymouth, UK
LeVoyageur 950 LVX
Always learning...
Hi all
I've just boight a new hose for my bbq but I am danmed if i can get the gas connector into the hose beyond the first 'notch'. Is there a trick to doing this?
a bit of lubrication .. I use a drop of washing up liquid rubbed around the spigot .. don't use any hydrocarbon products .. i.e. oil, WD40, etc
If it's a plastic pipe, soften the end by soaking in boiling water for a minute or so.. then push on quickly while still soft..
Thanks Jim, I was worried about using lubricants for the obvious reasons but i'll give these try.
I do it the same way as suggested by Jim. Also give the connector a wee twist back n forth as you put it on the hose. I find it makes it easier.
I do it same as you and Jim
Except I put a Jubilee clip on first ;):rofl:
I use a cable tie as it's only a fraction of one PSI
On braided hose etc, I always give the end a few smart taps with a hammer against the bench worktop, this excites the molecules (warms it up) and lets you push in the spigot, it's quick, no cross contamination and handy if you don't have hot water to hand (y)
