- Jul 28, 2008
- 1,155
- 1,522
- Ducato Sportivo
- Since 2005 2500+ nights in van - lost count!
I posted my failed AC pipe in the fiat section, but posting this in tech as it may apply other makes
Summary: Lower AC pipe on ducatos can touch the O2 sensor and melt the rubber section of the pipe and cause pipe to fail. On mine, MY20 160ps 2.3 Ducato part is £170 and 3hrs to fix + regass I assume.
I ADVISE EVERYONE TO CHECK THEIRS - AND IF SIMILAR - SEE IF THE CLIP IS PRESENT - if so/not - please post year/model
There was a recall in 2018 #6172 - that covers an intercooler issue AND the AC pipe - which is fixed by a cheap clip that pulls the pipes together. Squeezing mine together where the clip goes and the pipe DOES move 5cm away from the o2 sensor. In other words, the 2018 recall for a fix does not apply to a 2020 van but equally the fix was not applied from factory.
I called fiat, explained my issue and complaint, and they were about to pass me to "good will" team until I could not answer which fiat pro garage diagnosed the issue. The fact its a obvious melt in the pipe and a squeeze where the non existent clip should be moves the pipe is irrelevant. So in order to go to "good will" I will have to take van to fiat, book in and pay for a diagnostic fee (£150??) just to go to "good will" and potentially be told to sod off off or given a plastic clip! Seems a gamble to me.
The clip is £2.23!!!! (cheaper than £5-600!) - Part number (from recall) is 7719199
Suggest all sevel owners check their vans and buy/install a clip if its not there already.
Source here: https://lab-aftersales.fiat.com/elearn_testreda/250003211.pdf
Fuming with Fiat!
Ps - if anyone has changed the lower AC pipe (https://coastalmotorhomes.co.uk/fit...con-hose-pipe-2-3jtd-oe-14-on-1393951080.html) on these vans please let me know how DIYable it is? Headlight out or much more than that? 3hr quote to fix suggests its not trivial (but that 3hrs may include aircon test/regass etc)
Fuming with Fiat!
