Captains seat won't lock
normanandsue
Dunfermline - Scotland
van conversion
Have a N + B Arto 69G. Both front seats are of the captains chair type (ie they turn around) which should be locked when facing forwards. Sadly though my driving seat will only lock half way round. The locking device only operates to prevent the seat turning clockwise but not anticlockwise when facing forwards.
I have taken the seat apart and it appears a locking pin slots into a u shaped slot, which causes me to puzzle why it should only half lock.
As I drive with seat belt on it does not present a driving difficulty but I am feared if I don't get it fixed it will be an MOT failure.
Any one any ideas?
Norman
Can't help with your problem but it will certainly be a MOT failure.
The seat lock on my Fiat X2/50 failed and the 'very nice young man' at Adams Morey fixed it before they did the MOT testing to prevent a failure.
Hi Norman on a older van of ours the seat fastening nut came slightly loose and that alowed the holding pin to move and wear away the U slot.Fixed it by retightening the nut and adding a spot of weld to the worn bit :thumb:
terry
About 2008/9 there was a recall on the swivel type chairs your described. I believe it was the one with the orange type handle. The catch had a habit of slipping off the upright catchment pin and the seat moving forward. The remedy was to replace the whole mechanism with one where the catchment pin had a small dome welded to the top to prevent the catch from riding up and slipping off.
Ian
terry
It seems that has been tried, the castle nut had been tightened and a hole drilled through the bolt and a split pin inserted. A mh dealer tightened the nut and said he had fixed it, which he had for a short while. I tried doing the same with no success but it seems as if you have found the solution; the u slot must be worn away. I think it is a case of trying a dealer who might have had experience and hopefully a solution.
Many thanks
