X250 engine earth strap and failed hot start. (1 Viewer)
Ed Excel
870
547
Ribble Valley
Coach built
Started 2007
and if the reading stays at infinity not zero
Zero is good! it means the resistance is lower than a cheap test meter can register.
You're right, of course. My mistake,in looking for a figure to quote I didn't bother reading the text. Sorry about that. Ed.
Techno
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
Been out today and performed a good dozen hot starts without failure so it certainly has been a long time fault. Amen
Techno
Techno
Jul 28, 2010
15,475
20,756
May 2010
Another update
Still 100% first time starting.
I'll be the first to post if it ever fails again, (y)
Bobby22
1,537
6,408
Scotland
Rapido 680ff
since 2013
I had this problem with a Citroen Relay ... 1 year old , same engine I think, .drove 180 mile journey stopped ...seconds later it wouldn't start
RAC took off earth strap cleaned ends and refitted all ok
Aug 6, 2013
11,953
16,570
Kendal, Cumbria
Le-Voyageur RX958 Pl
since 1999
Another update
It would be worth soldering the ends whilst it's still clean. Copper & zinc are at opposite ends of the galvanic table - a slightly less than perfect (ie gas tight) crimp & corrosion will occur very quickly causing at best a rectifier & at worst a disconnection.
Techno
Techno
Jul 28, 2010
15,475
20,756
May 2010
Mine are hexagonally crimped in tinned copper lugs and taped.
Tinned copper has higher conductivity as well as anti corrosive properties.
Techno
Techno
Jul 28, 2010
15,475
20,756
May 2010
Yes exactly Tony
Mine is now made of insulated 70mm welding cable (left over from my solar battery bank to inverter connections)
Techno
Techno
Jul 28, 2010
15,475
20,756
May 2010
The missing picture
petrol tin glyn
123
95
Cardiff
autotrail cheiftain
since 2006
:LOL: transits were mentioned earlier, do you know what time it is when two transits pass each other on the road ;);) tin passed tin:xshout::xshout::xshout::xshout::xshout::xshout::xshout: only joking boys happy new year,
OllieUK
259
300
Ramsgate
Bessacarr E520
Since 2009
I need a new battery starter cable for my LDV 2.5 van what size cable should I be looking for?
Went into Halfords but they said I need to go to an LDV garage..
Jaws
23,836
72,487
Thetford Norfolk
C class, Chieftain
since 2006 ( I think ! )
I will tell you the weirdest problem I have come across that relates directly to what you have posted..
But first I will ask a question.
Is the Fiat gearbox bolted direct to the engine with steel bolts and making a perfectly solid connection ?
Of course it is....................
Well actually, and I have NO idea why, it isn't !!
At least three occasions I have had the issue, the most recent with a well known member of Fun.
Earth strap is perfect.. ends all clean and redone just in case
Yet would not start..
Fit another earth on the other end of the so called solid assembly and away she goes !!!!
It baffled me the first time I came across it and the two subsequent times I will admit to being equally mystified !
johnp10
7,774
15,181
North Lincolnshire
8 years ish
Ben,
Better to go to your local auto electrician.
They will have that info, have the right cable too.
More than likely cheaper than an agent.
Aug 6, 2013
11,953
16,570
Kendal, Cumbria
since 1999
More likely to be a poor chassis earth path? There are too many fasteners connecting engine-box-starter for a poor path through the engine/transmission assembly.
Jaws
23,836
72,487
Thetford Norfolk
C class, Chieftain
Nope.. Ask Brian ( Hilldweller ) if you do not believe me
Or perhaps he dreamed it as well or equally perhaps we are both idiots ?
