Where to get new one (1 Viewer)
Lisett
46
27
Ochiltree
Im a newbie.
I have brought my 89 kontiki up to date inside but I am left with this. Does anyone know where I can get a new or more up to date version. I have tried everywhere.
DP+JAY
2,533
14,782
Dalbeattie
Laika 5009
since 2007, 25 years tuggin before that.
Is there meant to be a picture or are we to guess what it is you want?
L
Lisett
46
27
Ochiltree
Im a newbie.
Sorry forgot to attach it. :Doh:
Or perhaps a more up to date Kontiki ?
Oooh a low blow Jay. However never a truer word has been said.:Blush:
tonka
10,830
21,528
Cannock, Staffs
A class Burstner 800
Since 2000
Caravan breakers seem the obvious answer.. do a web search there are quite a few around..
Jaws
23,836
72,479
Thetford Norfolk
C class, Chieftain
since 2006 ( I think ! )
If the existing one is working ok, why not just cover it over with a neat box ?
Even a hanging picture with a couple of nice spacers ( strip of beading wood perhaps ? ) would do the job :thumb:
Aug 6, 2013
11,953
16,570
Kendal, Cumbria
Le-Voyageur RX958 Pl
since 1999
Have you tried Magnum Motorhomes or O'Leary Motorhomes? Both usually stock a few options.
Aug 6, 2013
11,953
16,570
Kendal, Cumbria
since 1999
It's more a direct replacement I'm after. Olearys don't do one.
You won't find a more modern one that is a direct replacement I'm afraid. When they update manufacturer's tend to change everything. Best suggestion is to remove it, remove all the gubbins, then rub down & spray the front a colour of your choice using a rattle-can. If you print the appropriate words / symbols onto an OH projector slide using your PC / printer you can make a very professional job.
mcflipflop
4
Looe
c class
since 2007
mcflipflop
Hello all, I'm probably looking on the wrong page but does anyone know where I can get a rear ladder for my Autotrail Cheyenne, excluding the manufacturers.
thanks Mac.
TheBig1
17,630
43,277
no such thing as an exact replacement for that fuseboard, but there is very little can go wrong on them either
either respray it or cover with stickybacked vinyl to update its look
Terry
11,932
9,082
Lincolnshire
Can't remember ;)
Did you speak to O'learys or just look on the web site? You could always buy the Sargent unit off them to replace yours with @£150 Would not take a lot to rewire and you would have a nice 12 amp 3 stage smart charger built in to boot :Smile:
terry
Jan 28, 2008
10,116
18,382
Dovercourt, Harwich, UK
Renalt burstner
7 years campers before that
you could loose it all together its just a switch fuse box and meter tuck the fuses away inside a cupboard then find a switch and small meter, if you realy need it on display move it back and fit a door over it
L
Lisett
46
27
Ochiltree
Im a newbie.
I gave olearys a phone with no luck. There is absolutely no issues with it not working. It is as simple as you get after all. I'm just looking to bring it into the present time zone with the rest.
And if not then maybe the 90's.
Minxy
32,651
66,541
E Yorks
Carthago Compactline
Personally I'd leave well alone ... if it ain't broke then why bother replacing it? Instead I'd look to do something to disguise/cover it as has been suggested if it offends your visual senses!
It wouldn't take much to make a 'mock' cupboard to go over it, or a mirror, picture etc, which, if you put it on hinges, can easily be swung open to read the display when necessary, or if it's light then stick-on Velcro would do the job.
One thing to remember is that the next owner of your vehicle might like it to still have some of it's original fittings so removing it could actually prove detrimental. :Smile:
Terry
11,932
9,082
Lincolnshire
Can't remember ;)
terry
Here you are:whatthe: if you can afford it:thumb:
Hi Wizzer same unit as O'leary's do for £150 :winky:::bigsmile:
terry
