Water - didn't do wat I oughta! (1 Viewer)
Langtoftlad
8,861
150,864
Langtoft, South Lincs
WildAx Aurora FB [PVC]
Since 2015
Cold snap has taken me a bit by surprise - ie; I was working abroad and it was mild when I left.
So I've come today, freezing temperatures.
I've dived in the van and pulled the bung on the fresh water tank to dump it's 80 litres onto the drive.
I've opened the grey waste pipe, a dribble came out - tank was/is pretty much empty.
Opened the taps - nothing [the kitchen sink has a dribble] but nothing from the bathroom, basin, loo or shower.
I think my pipes may well already be frozen :crying1:.
I assumed the water heater would auto dump when the temperature fell below a certain temperature but digging out the handbook, it seems it might have a manual valve only - I'll switch it to drain a bit later...
Given that I haven't taken appropriate "preventative" measures - what can I do to minimise any damage/risk of damage to the pipe work.
Would it be a good idea to run the space heater [on low] for a few hours, perhaps raising the internal van temperature a bit, maybe slowly melt any pipes that are frozen...
I'm afraid I'm neither technically minded nor practically competent :rolleyes:, so please no advice involving spanners or tools in general.
Thanks.
Feb 16, 2013
19,735
52,032
uttoxeter
ambulance conversion
50 years
Thanks.
I would have thought if you have dumped your water there will be none to come out of the taps.
scotjimland
2,334
10,102
A Woosh bang
biggest risk from freezing are the taps/mixer .. expensive to replace.. but as said.. if you drained they should be ok.. leave them open
if worried do as you said.. warm the van up inside with all the cupboard doors open..
Jun 17, 2012
2,933
9,928
North Essex
Autotrail Delaware
>12 but <13
Temperature is rising in the day time, leave taps open.
Says the one who is about to drive to his storage to drain his own water !!!!
But will use as an excuse to have a drive in the MH................
Lenny HB
53,438
150,040
On the coast in West Sussex
Hymer B678 DL
I would be surprised if water has frozen, temperature only dropped yesterday (down here anyway), it would need to be quite a few degrees below zero for a few days for the van to get cold enough inside for pipes to freeze.
Langtoftlad
Langtoftlad
8,861
150,864
Since 2015
Only just dumped it about an hour ago...
Hope you're right - just thought what was already in the pipe runs would have flowed - unless frozen...
I guess I'll find out :cautious:.
Apr 11, 2015
5,415
55,198
hull
Laika Ecovip 300
Ditto
Feb 16, 2013
19,735
52,032
uttoxeter
50 years
If there is no water for the pump to pump it won't push much out of the taps , if you have a dribble I would say it's not frozen
Langtoftlad
Langtoftlad
8,861
150,864
Since 2015
This might sound like a daft question, it sounds daft to me... But when it gets warmer, and I fill up the tank again - given that most of the piper work appears to be concealed - how will I know if it's all ok...?
Langtoftlad
Langtoftlad
8,861
150,864
Since 2015
I only drained the tank this morning.
Are you saying that the pipes themselves, being 'flexible' might be able to handle being frozen - but the taps being rigid are more prone to damage.
I guess the positive, trying to ignore any expense, that at least taps are visible and so should any problems with them.
Off to put heating on...
Presumably that can be left on low - unattended ???
Jun 17, 2012
2,933
9,928
North Essex
Autotrail Delaware
>12 but <13
Pump will keep cutting in trying to maintain pressure if there is a leak, not to mention the eventual evidence of water where it shouldn't be.
irnbru
13,514
31,142
Glasgow
Benimar 264
11 yrs
I hope I don't have the same problem. I haven't drained down yet. Intended to do it yesterday but somehow the day ran away from me so last night I put the heating on low and the hot water on too so hopefully when I go to dream it later today all will be well.
9
9526
If it's a pressurised system it will not "pressure up" ie the pump will continue to run when taps are off.
You will also notice a leak, the pipes may well be hidden but the water will still run from under the cupboards.
As others have said the most vulnerable parts are mixer taps (we once had a shower head crack due to ice) the "hidden pipes" are a bit more protected (soft plastic can also stand a bit of ice without cracking)
Joints are vulnerable (they push apart as ice expands) but you will notice one of thes the minute you restart the pump as it will gush out.
Langtoftlad
Langtoftlad
8,861
150,864
Since 2015
God! It's flippin' freezin' out there!
So water heater valve [yellow] flipped to drain position - no satisfying sloshing of water :( but maybe, clasping at straws, it was empty anyway...
Just dismantled showerhead, and hose from tap connector - definitely frozed. Can see proper ice.
Heater on and already the inside temp is a balmy 1.6deg
Jun 17, 2012
2,933
9,928
North Essex
Autotrail Delaware
>12 but <13
Had slight air and ground frost here but how low did it get where you are?
OldAgeTravellers
1,207
1,387
Telford, UK
Since 1970
After draining down I always blow down the taps and shower to clear all water out of the system. Some I can get my mouth over and just blow hard till I hear no gurgling others I have a tap to hose connector. Especially make sure you do the hot with the boiler drain open as that is the most expensive thing to freeze. I also put an egg cup full of cheap AntiFreeze in the waste traps but be careful not to get any on your sinks some AntiFreeze can damage some plastics (or a couple of egg cups of meths if you don't have antifreeze) I also leave the waste drain tap open.
The worst place to clear is the Cassette flush if you have an electric flush. Usually before draining anything out I get the wife to press the flush button while I blow down the nearest tap, hold it for a few seconds after I stop blowing then release it the pipe should then be empty and not fill again while you clear the rest of the pipes. Also leave the fresh tank and water heater drain taps open. Also after doing all this run your pump dry for about 30 seconds to move any water that may be in the filter and pump into the flexible pipework where it will do little damage. Don't forget the shower in the garage if you have one as well.
Hope you have caught it in time before any damage.
Jun 30, 2010
7,924
27,229
Cornwall
1992 VW Auto sleeper Mono
Since 2005 this time
I drain down after every trip, blow thro the pipes and dry out the inside of the Water tank, and leave all the taps open.
Mid Oct, early nov I cover the water pump with an part of old duvet, (the plastic filter housing still is generally half full if it freezes it cracks) and I also cover the Boiler with the rest of the old duvet, this stays on until We use it again, and, until the frost season is over.
Aug 6, 2013
11,953
16,570
Kendal, Cumbria
Le-Voyageur RX958 Pl
since 1999
All this is why, if you have permanent access to EHU, it's good to leave a heater with a frost stat in the van over Winter.
JockandRita
11,462
150,162
Lincs/Cambs border
N+B Flair 8000i
Since May 05 (Ex Tuggers).
As you know, I'm only a couple of miles away from you, and although it was cold enough for the Truma valve on the hot water tank to auto dump, we didn't experience any freezing of the water system. On the coldest morning over last weekend, our internal temperature was still +5 degrees
The last time we had an internal frost problem (solenoid underneath the Thetford toilet bowl) the interior temperature was -5 degrees. :eek:
What make of MH do you have?
Cheers,
Jock. :)
Langtoftlad
Langtoftlad
8,861
150,864
Since 2015
Ace (Swift) 2004.
I know my shower pipe was frozen.
I strongly suspect water in other pipework was also forozen
Water in tank was liquid.
All dumped, taps & valves now open
Guess I'll find out when I fill it up again :rolleyes:.
JockandRita
11,462
150,162
Lincs/Cambs border
N+B Flair 8000i
Ace (Swift) 2004.
If you need any help in the meantime, just shout. (y)
Cheers,
Jock. :)
