warning Light? (1 Viewer)
May 16, 2010
3,213
2,535
North Hykeham
Custom
much more now
I took the MH to Towtal yesterday to have my new towbar fitted.
Fiat 2.8 JTD 2002
On the way there (and back) the injector warning light would pop on then off, especially if I backed off the throttle a bit. I could pull 70 to 80 mph easily with no problem but if I hit 2800 revs in 4th it would pop on and if the engine was loaded eg. when going up an incline but still pulling well.
It appears to be very intermittent.
Any ideas?
Thanks in advance.
BTW
The new towbar is brilliant but the wind and cold cut us in half whilst we had to walk around Hanley for a few hours while it was being made and fitted.
kiwicamper
111
94
christchurch NZ
fully intergrated
since 2000
Fiat 2.8 JTD 2002
Any ideas?
Thanks in advance.
BTW
any chance the guy who fitted towbar has somehow buggered up the wiring?
last time I had a towbar fitted they stuffed up the piping to my water tank.perhaps youhave had some wires disturbed.
WynandJean
6,670
3,303
West Midlands
Bailey Autograph 682
Since 2010
Looks like it was happening before the fitting as he says it was happening on the way there and back.
Wyn
jhorsf
9,130
8,045
DERBYSHIRE
ih oregon
injector wiring has been a problem on that model as in its too short and pulls on the connectors you can reroute this a bit to help and check the connections are tight on tight plugs be careful not to mix them up you can sometimes tighten the plug by squeezing it carefully so as not to break it.That would be my best guess.
see here for more details
http://www.fiatforum.com/ducato/280730-2-8-jtd-injectors.html
Geo
Trader - Funster
Jul 29, 2007
11,757
14,565
Mansfield,Notts
Autotrail Tracker FB
45 +years with breaks
Wyn
Never let the truth get in the way of blaming the last man (usually a fitter) getting the blame:Doh:
G
rainbow chasers
3,680
1,725
Mid Cornwall
Various
Check around the fuel filter housing/hand pump as these can be known to leak and cause low pressure. Check the injector loom is attached properly, as these are known to be a little short on some vehicles and can pull out. If all avenues have been tested, then have the injectors/injector seals looked at
acting_strange
May 16, 2010
3,213
2,535
North Hykeham
Custom
much more now
G
To be honest I have had a look at the new Towbar fitting and they have done a fantastic job :)
I would easily recomend them...
acting_strange
May 16, 2010
3,213
2,535
North Hykeham
Custom
much more now
Just to give further information....It only seems to do it when its warm/hot....I took it to 3500 revs when cold and it was fine....came back after a short run and it started doing it and I noticed the engine had reached operating temp...slight loss of power too until I backed of then accelerted again...would this be the ecu cutting into "get you home mode"?
acting_strange
May 16, 2010
3,213
2,535
North Hykeham
Custom
much more now
Almost certainly wastegate siezed. I have had to do both mine & friend this year, easy fix.
Thanks for this......so now where is the wastegate band how do I fix it? ::bigsmile:
Big hammer??....Bigger Hammer???....get swmbo to shout at it ????
DP+JAY
2,533
14,782
Dalbeattie
Laika 5009
since 2007, 25 years tuggin before that.
A squirt of WD40 ans a pair of mole grips on the little arm arrowed.
You will need to get under the van by the door area, from behind the front wheel, depending on the van you may need to lift it, so care needed.
Look up the back of the engine & identify the turbo which will look similar but not identical to the picture.
Doesn't take much effort & it doesn't move very far so do not force it.
file:///C:/Users/djp30/Desktop/WastegateStickingFigure3.jpg
acting_strange
May 16, 2010
3,213
2,535
North Hykeham
Custom
much more now
Thanks Jay....will give it a go...You're a star :thumb:
Jun 17, 2012
2,933
9,928
North Essex
Autotrail Delaware
>12 but <13
Light on at 2800rpm
I had similar problem, here is an extract of a post 18th March
I bought my MH private. Fiat Ducato 2.8JTD. My red MIL came on at 2800 rpm. Then went out when foot off gas. Not too bothered as son has garage. Plugged it in, came up as "overboost". No problem says son, bet waste-gate on turbo seized. Yes it was. Free it and hey presto and it revved freely. However, the red MIL indicates an injector problem. Well yes in a way, as due to overboosting the ECU shuts off fuel to the injectors, so the message WE GET (humans!) is injector problem.
I had cause to ask previous owner about something else, he said light came on and he thought it was to prevent over-revving.
Seems it had been seized when stood idle at the dealers some time before he purchased it.
The fault came up as a P0235 fault code.
Good luck and keep us informed.
jetsets
10
derby
hitop
newbie
fixed mine
HI There
used the pic and info on this thread. Very useful, My warning light was coming on when going up hills or accelerating to overtake, sometimes power was lost and you had to fiddle with revving back and gear changes to get it going again. Called AA out this morning as the light was on a lot, plugged in computer and no fault codes were there. So we ( me and AA) went for a ride, demoed the problem, but as there were no obviousl faults codes or wires or pipes off all they could do was reccomend me to take it to an expert.
So I thought I would find the turbo and look at the wastegate. Found it ( hard to reach crawling under van) few sqirts near pivot point on arm, used mole grips and gradually freed it off, being careful as I dont know how far it is supposed to move. Anyway got it moving and went for a run - feels better and no lights!
SO Many thanks must have saved me a fortune..:RollEyes:
Jun 17, 2012
2,933
9,928
North Essex
Autotrail Delaware
>12 but <13
HI There
used the pic and info on this thread. Very useful, My warning light was coming on when going up hills or accelerating to overtake, sometimes power was lost and you had to fiddle with revving back and gear changes to get it going again. Called AA out this morning as the light was on a lot, plugged in computer and no fault codes were there. So we ( me and AA) went for a ride, demoed the problem, but as there were no obviousl faults codes or wires or pipes off all[HI] they could do was reccomend me to take it to an expert.[/HI]
So you did consult an expert. You consulted MOTORHOME FUN!
Well worth every penny of £10 for the info, I know mine was well spent.
Glad it worked, knowing you deprived a Fiat Main Stealer of cash is the best bit though!
jetsets
10
derby
hitop
newbie
next job
Yep thanks
Now on to another task, stopping the creaking in the worktop/cabinet work near the cooker- its a dakota. Found the culprit, I think its the metal plate behind the cooker squeaking agains the woodwork - not the cabs - when I take it out ( its just jammed behnd the work top) Its hard to make it creak - as soon as its in then I can hear a creak when I lean on the cabinet. Its been getting on my wick for over a year now . Had to remove the cooker though to find it.:Confused:
Silkcut1105
1,981
13,319
Swansea
autotrail chieftain
Since 1991
warning light
ive got a 2001 fiat and the injector light has been on for the last 2 years ive taken it to fiat in swansea and they cant find anything wrong at all i think its a loose wire somewhere ?but cant find it.but so far no problems with rough running or anything.touch wood.
WynandJean
6,670
3,303
West Midlands
Since 2010
I'm sure I heard recently that any warning light showing will now mean a failed MOT. That could be a problem.
Wyn
Deckard
513
469
Lancashire
...looking
Noob
my warning light has been on for about the same time (2 years) and it just passed its mot yesterday::bigsmile:
The law hasnt been enforced yet....will be for your next one though :cry:
Apparently its the MOT catching up with technology...just feels like the garage gets to charge me even MORE each passing year!
jetsets
10
derby
hitop
newbie
still ok
well its been out on two trips now since I freed the wastegate and all is still well.!
Jun 17, 2012
2,933
9,928
North Essex
Autotrail Delaware
>12 but <13
Glad it worked. Nice feeling when a worrying problem is actually a freebie fix!
