Vision plus dual rear camera (1 Viewer)
Popsickle
Wales
Coach built
Since Feb 2014
Hi, has anyone got one of these fitted to their van and if so have you encountered any problems?
Had one fitted by dealer when we bought our van approx 6 weeks ago. The small camera for close up reversing is fine but the long distance one that is used as a rear view mirror as well as for reversing seems to mist up within a short time after setting off it sometimes improves then mists up again!
Nothing on outside as hubby has climbed up to clean it several times.
Any ideas?:Blush:
RandallC
1,242
3,488
Devizes
A Class Rapido 8096
2012, prior too, 17 years Folding Camper & Caravan
Might be sun light!
If you can park up with it misted up then use something to shield the camera from bright light you'll see if that's the problem. Same effect as sunshine ona tele or satnav screen.
Good luck
Aug 5, 2012
125
99
Southampton
van conversion
since 1981 on and off
I have dual camera system no misting, it may be a small water leak in the camera. It should be under guarantee so take it back for them to sort.
