Victron or Voltronics ? (1 Viewer)
Jan 19, 2013
132
109
Worcestershire
since 2010
OK, as you may have seen from my "EBL99 Stopped working post"; i think i'm all fixed on that now with the EBL99 now repaired and an auxiliary 18A charger added. All appears to be working well. (y)
So now back to my Solar charger upgrade from 10 months ago.
I removed the Sunsaver 6 charger as I began to mistrust it after I observed what it appeared to be doing (monitoring via my Victron BMV600 & a Fox D1 display connected to the Sunsaver). Also I didn't like the way it was 'spliced' into the cables from the EBL to the Batteries :rolleyes:
I want to install an MPPT charger & have decided that it will be either the Victron (75/15) or the Votronic (250 Duo). The max solar cells I well ever go to will be 200 W. (currently 100 W)
The Victron is only a single charge output. Good; ..... so really simple to install. But will only charge the Leisure batteries. (I don't want to mess about with wiring / split relays etc... to charge the starter battery)
The Voltronic is dual output but looks a more complex product with; Appliance output; Starter battery output and a (single) connection to an EBL (I don't understand what this connection is for ?)
My view is; I am never stationary at a site for more than 3 days (without being on EHU) for me to worry about needing "solar" to charge the starter battery. i.e. i'm on the move or I connect to EHU.
Therefore I reckon the Victron is quite good enough for me.
HOWEVER: Questions ...... I cannot see any significant advantages in connecting the Victron solar charger to Block 6 of the EBL99. As I believe, all the EBL99 will do is : o_O
1.) If not on EHU, the EBL99 simply passes through the solar charge current (through an internal 15A fuse) to the batteries.
2.) When on EHU, the EBL99 will "see" the solar charger voltage and is likely to only charge the batteries when it's 1st connected (i.e. the initial Boost timed period set in the EBL) and after .... that only when the batteries are demanding more than the solar charger can provide.
So, with an EBL99 & MPPT solar charger I cannot see any disadvantage in connecting straight to the batteries. (the EBL99 will still 'see' the solar charge voltage at the batteries & so will still operate as point 2.) above ... ?)
If i'm mistaken or I am not considering some other important factor(s) .... comments welcome please. :unsure:
Lenny HB
53,435
150,025
On the coast in West Sussex
Hymer B678 DL
Yes, that is correct the EBL99 is a straight pass through via a fuse but connecting via the EBL makes the wiring a lot easier. I know you said you are not bothered about charging the starter battery but it is very easy to wire a split charge relay via the EBL.
Sep 23, 2013
2,585
8,773
Lincs
Globecar Campscout
Both are good controllers. If you do go for the Victon, all you need to charge the starter battery too is a Battery Master, available from Jim's shop (see advert on the right, or below if reading on a phone). Very easy to fit, just connect at the back of the EBL.
With the EBL99, it doesn't matter whether you connect the controller straight to the batteries or to the EBL. Do whichever is most convenient.
Oct 29, 2008
5,069
5,952
West Yorkshire
PVC
since 2008
I will be buying a votronic as I want the AGM settings and the starter battery output.
eddie
8,157
41,270
Taunton Somerset
RV
since 1989
I have seen voltronic "products" badged with differently so not sure they design and manufacture all their own products.
Victron are huge in the multi million pound marine market, designing anfd manufacuting bespoke systems
We can sell either, I'd only fit Victron on my own motorhome
Oct 29, 2008
5,069
5,952
West Yorkshire
PVC
since 2008
Votronic do design their own and they are made in Germany (so I have been told), Alden have them made by them. If you ask about Votronic on German forums they are highly thought of. Schaudt also recommend them if (If they are out of stock of their own MPPT regulator). I have no doubt that Victron do top quality products for marine etc, but is their lower priced motorhome gear the same quality. Ive seen Chinese regulators that look exactly the same as Victron. Are they copies or do Victron have their lower end stuff made in China?
gerry mcg
1,650
2,573
Glasgow, Scotland
Globecar 600L Revn
since 2016
I had a Victron 75/15 MPPT solar controller managing a 150W solar panel connected to my Shauldt EBL119 by @eddievanbitz last week, and he used a Battery Master to keep the Starter battery topped up. ;)
eddie
8,157
41,270
Taunton Somerset
RV
since 1989
Do you have a link?
As I understand it it, the quality is always the same, the bits are just smaller
Oct 29, 2008
5,069
5,952
West Yorkshire
PVC
since 2008
JeanLuc
3,304
2,199
Warwickshire
Hymer B630 Star-Line
I believe Votronic equipment is made in Germany and in the past, Udo Lang at Schaudt recommended their battery computer to fit alongside my EBL99 (in the event I did not spend the money to buy and fit it).
Here is a picture of one of the Votronic regulators clearly marked 'Made in Germany'.
eddie
8,157
41,270
Taunton Somerset
RV
since 1989
They had them at shows.
Ah!
Well I have never seen Victron stuff rebadged, and we import Victron direct from Holland, so are always looking at pricing and supply.
If you can provide a link to copy Victron equipment I'll make sure Victron get it
Victron of course is standard fit in a lot of the higher end German Motorhomes.
Oct 29, 2008
5,069
5,952
West Yorkshire
PVC
since 2008
Ah!
I don't think its Victron rebadged exactly, its either that Victron get stuff made in china and the same factory supplies other brands, or its an item designed to look exactly like victron but with out the name,
eddie
8,157
41,270
Taunton Somerset
RV
since 1989
I'll check on the first, and you can hardly blame Victron for the latter
LOL The world is a confusing place
funflair
19,352
30,242
Guisborough
MORELO palace
since 2012
Thats an in interesting link Eddie, I am assuming that the OP really meant "votronic" when he typed "voltronic" your link to "voltronicpower" seems to show the MPPT controller that is sold as "solar" and much favoured bt @Techno and others.
Martin
iceclimber
Jan 19, 2013
132
109
Worcestershire
since 2010
Oops ......... Title of my Post should have read "Victron or Votronic" :notworthy: ! (as in the post I referred to the Votronic (250 Duo)
Amazing that there is also a Voltronic Solar product ? Is it possible that this where the Chinese vs German origin of manufacture / design debate has crept in :sick: ?
funflair
19,352
30,242
Guisborough
MORELO palace
since 2012
I knew what you meant;) but at that point I didn't know that there was such a manufacturer as Voltronic.
Martin
eddie
8,157
41,270
Taunton Somerset
RV
since 1989
Martin
I only posted it as Jesport said Victron have stuff made in China or knock off, but no supporting proof, just "he thinks" so, for a giggle I posted the link
Both, as Trump would say "Fake news";)
