Victron understands that space is at a premium in motorhomes / caravans and saving space is always an added bonsus. The Victron Phoenix C Compact range offers a lot of performance for the space needed. Developed for professional use the Victron Phoenix range of inverters are suitable for a wide range of applications as they have been designed to achieve a true sine wave output with optimised efficiency without compromise to performance. Using hybrid HF technology the result is a top quality product in a small form factor.
Victron Energy Phoenix Inverter C Features:
- Extra start up power - allows you to use the inverter with difficult loading situations such as computers that require a very high start up power.
- Can be programmed from a computer to modify preset DIP switches.
Pheonix Inverters C 12/1600
Continuos Power at 25°C (VA) 1600
Continuos Power at 25°C / 40°C (W) 1300 / 1200
Peak Power (W) 3000
Output AC Voltage / Frequency 230 VAC +/-2%
Input Voltage Range (VDC) 9.5 to 17.0
Max Efficiency (%) 92
Zero-load power (W) 8
Protection Output Short Circuit, overload, battery voltage too high, battery too low, temperature too high, 230 VAC on inverter output and Input voltage ripple too high
Operating temperature range -40 to +50°C (Fan assisted cooling)
Humidity (non condensing) Max 95%
Material / Colour Aluminium in Blue
Weight (KG) 10
Dimensions (H x W x D mm) 375 x 214 x 110
OPEN TO OFFERS
Approx £900 new
Dave
