Vento fridge fan kit faulty ?
Discussion in 'Fridges & Ovens' started by Spanner, Jul 4, 2016.
  1. Spanner
    Spanner Funster
    Nov 7, 2015
    96
    44
    Shropshire
    I've now fitted two of these kits which don't work as I expected.
    The first kit started running when the ambient temperature was only 20°C and cycled on / off every 5 seconds, adjustment of the trim screw made it run constantly !
    I fitted a complete replacement kit today.
    With the fridge switched OFF the fan switch in auto mode and an ambient temperature of 22°C the fans were still but as the temperature around the fan thermistor sensor hit 26°C the fans started then as the fans cooled the thermistor the fans stopped, but within seconds the fan motors began to emit a high pitched squeal before starting to spin again and continued to cycle in this way on off squeal on off
    Adjustment of the trim screw only varied the fault by 1°C
    The high pitch noise definitely does not come from the control box
    Have I received two faulty fan kits or is there another reason, any suggestions welcome.
    Thanks in advance !
    This post has been moved from the heat and cool section, sorry !
Similar Threads
  1. Spook.
    11
    133
  2. 2bob
    140
  3. foxypop
    10
    290
  4. Robert Clark
    30
    1,478
  5. Darren
    8
    591
