TYRE PRESSURE/TEMP MONITOR (TPMS) (1 Viewer)
lou020
489
360
huddersfield
autotrail chieftain
since 2010
Anyone got one of these TPMS fitted, i fitted mine this weekend, but did'nt know what to set the high temperature at. Iv'e read somewhere tyres can reach 90deg F.
Also if the tyre pressure is running at 80psi what will the high pressure limit be.
Any ideas?
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
Perhaps you should start low and if all six sound the alarm then obviously it needs increasing. Eventually you will find the normal running temperature.
lou020
lou020
489
360
huddersfield
autotrail chieftain
since 2010
What do the instructions say? surely they offer some guidance
nope,, just says default settings 150psi,,i can't remember for temp,,,minus 30c i think.
it is for trucks also,which run at 130psi so i suppose 20psi above normal.
Techno
Jul 28, 2010
15,475
20,756
May 2010
Surely it is monitoring a pressure DROP not an increase? I would set it a few PSI below
Temperature monitoring must be for high so start at 30c
lou020
lou020
489
360
huddersfield
autotrail chieftain
since 2010
you can set it for low pressure and high pressure, also low & high temp.
it seems very accurate with the pressure thats in them now.
Techno
Jul 28, 2010
15,475
20,756
May 2010
I don't see how low temperature is a consideration at all, you can't control that.
The alarm should be set to notify of low pressure and high temperature as hazards.
An under inflated or deflating tyre will get hot not cold
lou020
lou020
489
360
huddersfield
autotrail chieftain
since 2010
yes,that's what i thought, maybe its for when the Chinese are driving up the himalayas.
funflair
19,352
30,242
Guisborough
MORELO palace
since 2012
We have the tyre-pal system and I would say set the high pressure alarm about 8 or 10 psi above your normal running pressure, if you set it off I would suggest that the tyre pressures are actually too low and the sidewall flex is overheating the tyre and affecting the pressure. I have found that the ambient temperature has very little affect on the tyre pressure increase it is the distortion of the side walls that builds up the heat.
As for temperature you could start with 40 degC, I have not seen ours above this but we are using the flow through monitors so might be different.
Martin
Techno
Jul 28, 2010
15,475
20,756
May 2010
Given what you say it sounds like you can set high and low pressure plus high and low temperature?
Most of us don't go out n about when it's freezing so IMHO I'd start off with temperature at low 0 high 35
Pressure at low 5 psi below normal and high 5 psi above normal and then adjust aftyer driving. The tyres should feedback normal use.
funflair
19,352
30,242
Guisborough
MORELO palace
since 2012
I should add that as you drive it will scroll through pressure and temperature so with a bit of experience you can fiddle with the set points.
funflair
19,352
30,242
Guisborough
MORELO palace
since 2012
Hi Andy
That's about what I started with but about 10 miles down the road all the alarms were going off, the fronts climb about 7 psi from 58 to 65 and the rears go up 5 or 6 depending what pressure I am running.
lou020
lou020
489
360
huddersfield
autotrail chieftain
since 2010
yes, thats what i have set it at, give or take a psi, i set the hi temp at 35.
i wont be trying it until we go to lincoln, but i suppose i'll have to experiment with it especially in the summer when abroad.
Thanks to you both for your help and info.
Cal54
3,806
62,033
Southport, UK
Leisuredrive Renoir
Since 1996
Hi I have the Tyre Pal system fitted and originally set the pressures with a variance of +10% and - 5% (as recommended by the guy that sold them at the NEC). I found the alarm was going off regularly so consulted the instructions and have now reset. The temp is advised as a factory setting of 70 degrees and I haven't messed with this. Had I not had this unit prior to joining the Funsters I would probably have gone with the LED monitors sold by Jim - a lot cheaper!
lou020
lou020
489
360
huddersfield
autotrail chieftain
since 2010
Hi Cal, thanks for that, i had Jims LED's on my last m/h, but i thought it would be better to monitor them whilst traveling + i would have needed 2 more as the new m/h is a tag axle,
Sep 3, 2013
768
816
Crowthorne, Berkshire
1992 RMB Silver Star 670
One year. A whole one!
I also have the TyrePal on Udo. I find all tyres increase by around 10psi front and rear when running.
I've not altered the temperature set-point but it took a bit of fiddling to stop the high pressure alarms going off. I was surprised how much higher they get. Maybe I should increase their pressures a little more? I'm running 60 / 65 front / rear.
In my view, the TyrePal is well worth it. I've just bought a set of Jim's valve cap monitors for one of my cars. Wouldn't work on Udo as his stainless steel wheel covers hide the valves completely.
SMB
Apr 26, 2013
1,230
1,347
Spain
Coachbuild
Fulltiming since February 2013
I have the Tyrepal TB99 system and I set the tyre pressure warning at 20% above the regular pressure (5.5 bar in my case). As mentioned previously the pressures rise considerably and I had to set mine higher than the initial 6.1 warning I programmed.
funflair
19,352
30,242
Guisborough
MORELO palace
since 2012
Hi Bellini
Ours dont rise as much as 10psi but what tyre size are you on and what axle weights.
Martin
Sep 3, 2013
768
816
Hello Martin, I'm on 195/70/R15 tyres. I'm unsure of my axle weights but I know I'm at 4.6tonnes fully loaded. Most of that will be over the rear axle.
funflair
19,352
30,242
Guisborough
MORELO palace
since 2012
Ours are 225 75 16 so yours might be working a bit harder and therefore generating a bit more heat/pressure, saying that we are 1 tonne heavier.
longdog
Banned
Apr 16, 2013
255
287
I have fitted Tyrepal and found it to be very good indeed.
Tyrepal recommend the following alerts:
High pressure alert, 20% above recommended pressure
Low pressure alert, 15% below recommended pressure
High temperature is 70C by default
