I would like to remove the black cover that the aerial is mounted on to check out the earthing of our aerial as I think ours is duff. The trouble is, everything I've read so far about removing this cover (to replace a wing mirror) says to break off the cover which I don't want to do!
To be honest, I'm not sure that the cover can be removed without taking the whole mirror off as it completely surrounds the stem to the mirror. As this is fitted with shear bolts it's gonna be a bit of a pain to do. :Sad:
It may prove easier to use a windscreen mounted aerial in the long run but I'd like to try and fix the present one if possible.
Tim
Tim
