I want a damp meter! (1 Viewer)
Munchie
8,921
12,581
Camping Les Vigeres
Font Vendôme
Since 2004
Just for checking the van out from time to time.
I want a good non invasive one.
Any recommendations?
Feb 16, 2013
19,735
52,023
uttoxeter
ambulance conversion
50 years
Ends of your fingers, or your nose!
irnbru
13,514
31,142
Glasgow
Benimar 264
11 yrs
I just borrowed one an hour ago. Was very impressed how it picked up on our little bit damp. Will need to find out the make of it as I think we will be buying one too.
May 7, 2013
845
1,353
RUK
On our 2nd MH now a AutoTrail Savannah which we're absolutely delighted with
I bought this one after recommendations on here ..
CEM Non Contact Moisture Meter - DT-128
Link Removed
I used it to check the van I have just bought.. very easy to use
Just ordered the same one last week delighted to hear your comments!
GJH
29,450
38,827
None, now sold
2006 to 2022
I bought Broken Link Removed after seeing it recommended on here. It seems to work OK but the sensor is on the back so Jim's is probably a lot easier to use in confined/awkward places.
Apr 27, 2008
11,842
14,071
Eastbourne East Sussex
Hymer low profile
Since 1972
Found mine useful in the house. A replacement window fitting had damaged the membrane over the lintel and water was coming in . Now all fixed.
D
Deleted member 29692
Link Removed
Ordered one yesterday, arrived today. Looks like a good bit of kit.
As a guideline what sort of figures would we expect for:
Fine
OK but keep an eye on it
Borderline
Damp
Wet
Panic
DP+JAY
2,533
14,782
Dalbeattie
Laika 5009
since 2007, 25 years tuggin before that.
Under 20 = OK
20 to 50 = Damp
Over 50 It's a boat, not a camper.
Great bit of kit but remember, it measures cunductivity, so keep your fingers away from the ball in use.
Readings will be affected by cables & metalwork etc. so practice a lot till you get the "feel" of it.
schojac
339
234
Cambridgeshire
new in 2009
I don't believe it, bugger and all that.
Thought I would give the van a good going over with my new meter :) "as above link"
3 inch circular damp patch discovered at one of the awning connection points. The main benefit I have now found with this type of meter, is that it is possible to constantly track the readings as the ball is moved over the test area. This allows the damp area to be quite accurately plotted which is not possible with a pin type.
Thanks ScotJimland for link; £49.00 well spent and recommended.
Baggers53
187
221
Stafford
My CEM non contact moisture meter DT 128 arrived today.....I have been practicing and this seems like a good bit of kit....thanks to all who contributed...Mike
Bluemooner
1,723
8,074
Ribble Valley
Dreamseeker Fifth Wheel
4 years
Munchie only wants a damp metre because Soggy is moving near him :giggler::giggler:
Mack100
766
2,697
Swift
I bought one of those CEM meters that have been recommended on here, had a lot of trouble last year with damp due to faulty construction. The MH went back to the manufacturer for a few weeks for remedial work so I thought I'd leave it until summer weather before I re-tested.
It has been raining heavily for a few days so I thought I'd test with the new meter. Surprisingly it showed very high readings (40%+) in the previously affected areas but weirdly the pin types I had been using showed very little damp!
So, it's possible that the new meter is duff or the new meter is accurate and the pin type is duff or I'm an idiot!
The dealer (curses be upon him) is so busy they won't be able to do a damp test so it's likely I'll have to wait until September for the hab service by my independent man (praises be upon him).
I suppose I could always lash out and buy a Protimeter:cry:
