Hole cutting (1 Viewer)
Keith E
108
56
I'm thinking about doing something like this on our Approach.
I'm not planning on fitting a second tank, this was the only diagram I could find.
I like serviced pitches when I can get them.
Obviously I'll need to make a hole in the moho to fit the inlet into.
I was hoping to put it somewhere near the existing Whale inlet, because it seems to me to be the most logical place.
Has anyone cut holes into their Bailey, and if so, what are the does and don'ts?
Cheers in advance.
Keith E
Keith E
108
56
I thought of that but I'm greedy.
I want both options.
Geo
Trader - Funster
Jul 29, 2007
11,757
14,565
Mansfield,Notts
Autotrail Tracker FB
45 +years with breaks
Buy the correct hole saw for the job let the tool do the job,messure three times and cut oncel
Be mindful of hidden framing and wires, pretend it's someone else's moho
3
34127
Anytime you are cutting a hole in metal be sure to thoroughly wash down the paintwork afterwards to prevent any metal filings causing rust spots.
Aug 6, 2013
11,959
16,575
Kendal, Cumbria
Le-Voyageur RX958 Pl
since 1999
If you haven't used a hole saw before:
Drill a 6mm hole central to where you intend to install the inlet. Try to drill straight.
Use the hole saw pilot drill to enlarge the 6mm hole in the outside skin if necessary.
Hold the drill very firmly and run it high speed as you engage the hole saw - you can slow it once you are confident it has started correctly.
It might sound counter-intuitive but high speed reduces the likelyhood of the saw 'grabbing'.
Ignore all the above if you have done it before.
Keith E
Keith E
108
56
Thanks for the guidance guys.
I'm no stranger to cutting holes, I just wanted to know if there's anywhere I shouldn't drill.
Keith E
Keith E
108
56
Why would you, the Whale one is a horrible caravan contraption. :D
So that I have the option of either filling the tank from a hose or leaving the hose connected to mains, thus bypassing the tank.
I'm getting rid of the Whale filler anyway.
Geo
Trader - Funster
Jul 29, 2007
11,757
14,565
Mansfield,Notts
If contemplating using what the Amercan RVs term City water or mains in the uk you shoul thi k about using a pressure regulater in your water hose a d do a thourough check on pipe conectuons inside
Vic
Aug 1, 2010
467
542
Keith,
This is what I did to my 2012 740.
Nov 7, 2015
497
469
Newport, Shropshire
Autosleeper Broadway
since 2015 previously caravaning 25 years
When I fitted a standard water filler to ours I started with a small hole say 2-3mm diameter drilling from the inside, only drill just through the inner panel then probe through that hole with a thin screwdriver to make sure you’re not hitting anything important then go from there, easier to rectify a small mistake on the inside than the outside !
Keith E
Keith E
108
56
Yes, there's one shown in the diagram.
