Geo re: flasher buzzer (1 Viewer)
43,329
49,444
hi Geo,
got the buzzer you suggested but unfortunatly your info was wrong:Doh:
5 wire system.
power in/out to left indicator
power in/out to right indicator
common earth. (presumably for relays !)
if its connected to cab end wiring the buzzer will sound regardless of trailer/toad attached or not. it must be connected between 7core cable and van indicator wires.
ie: no toad attached = no earth/continuity through toad bulb = no buzzer.
connect at flasher unit will mean an earth/cont will be present through M/H indicator so it will sound when M/H indi's are used. :Sad:
(unless you know a dsifferent way)
its a long way from the rear end to the drivers seat and the buzzer aint that loud.
no big shakes though as it was only £2.75.
thanks for the link all the same. :thumb:.
john.
