Gas bottle question? (1 Viewer)
Apr 18, 2009
3,569
3,367
Englishman in Mid Wales
Hymer B584, A Class
Not long enough!
At the moment I have two 6kg bottles in my B584 locker but it looks like I can get bigger bottles in there but what size bottles will it take? 11kg, 13kg anyone know please??
scotjimland
2,335
10,111
A Woosh bang
measure your locker..
next size up for propane is 13kg
Capacity 13kg
Height 580mm
Diameter 315mm
full spec here Broken Link Removed
If still unsure, take the van to a Calor dealer and ask to try an empty 13kg propane
Feb 24, 2013
13,083
101,454
Bolsover, Derbyshire
Hymer S800
not long enough
Not sure if our Hymer has the same lockers as yours, ours has a small flap at the bottom that we can lock in a slightly different position, that just allows us to fit 1 x 13kg and a 6kg alongside. Very close to 2 x 13kg but not quite close enough
It does look like the locker door is not quite closed in that position but it is
I get very confused on sizes and weights, I was not aware of a 11kg, but if they exist 2 of them might fit, but if they are simply butane which I think weighs less in the same size container there will be no gain just less gas and possibly wrong regulators :)
wizzer59
Apr 18, 2009
3,569
3,367
Hymer B584, A Class
Not long enough!
Hi Jim thanks for that, Flo/gas do a 11kg propane one but TBH there isn't much difference in size to a 13kg bottle(y)
wizzer59
Apr 18, 2009
3,569
3,367
Hymer B584, A Class
Not long enough!
Hi David yes mine has a flap as well, I will have to try one in my local garage and if it fits then the flo/gas one will as well, thank you(y)
Lenny HB
53,448
150,065
On the coast in West Sussex
Hymer B678 DL
All Hymer's are designed to take 2 x 11kg German gas bottles. Depending on your locker location you may have a bit more room, it it is located inside the garage you should be able to get 2 x 13 kg bottles in. We have 2 x 13kg (26Lt) Alugas re-fillable bottles in ours.
lou020
489
360
huddersfield
autotrail chieftain
since 2010
my chieftain gas locker would fit 2 x 11kg propane or 12kg butane from flogas etc, but the calor 13kg is about 1inch too tall. its the calor shroud that makes them taller, also they are a bit wider.
i just need to get hold of a flogas type bottle as the gas for a 11kg is less than a calor 6kg
Feb 24, 2013
13,083
101,454
Hymer S800
not long enough
I was a bit worried when I first tried it, the plastic toggles look quite strained, but we have done this now for 2 years, the saving in the price of gas will pay for new catches if ever needed, presuming it is still save to drive if one breaks. The straps take 99% of the strain, it is just that the bottom flap is tight up against a 15kg where there is a bit of room with 6kg/ I actually have my 13kg at a very slight angle to relieve some of the strain
(y)
edit - the problem is girth not height with the 13kg Calor
wizzer59
Apr 18, 2009
3,569
3,367
Hymer B584, A Class
Not long enough!
Thanks for that(y) I did wonder why its so large, the 6kg bottles do look lost in there;)
wizzer59
Apr 18, 2009
3,569
3,367
Hymer B584, A Class
Not long enough!
(y)
Maybe if I keep a lump hammer in the locker then:giggler:
Feb 24, 2013
13,083
101,454
Hymer S800
not long enough
The catches are only plastic, slight over kill the hammer :D
The only reason for the bottom flap is to give the top flap something to lock against, they are not the most secure of doors anyway, it is more for looks than function, I suspect you will have the same size locker as us, so hopefully you can squeeze one in as well (with slight bulge!!) (y)
Aug 6, 2013
11,953
16,570
Kendal, Cumbria
Le-Voyageur RX958 Pl
since 1999
I have two 11kg Gaslow in my B584 locker without adjusting the lower flap (which I can't do now anyway because I've replaced it with a fixed stainless part).
Minxy
32,659
66,566
E Yorks
Carthago Compactline
You been reading how I managed to get my 11kg Gaslow bottle into my PVC's locker which is only meant to take 2 x 6kg ones by any chance :) ... a lump hammer came in very useful! (y)
wizzer59
Apr 18, 2009
3,569
3,367
Hymer B584, A Class
Not long enough!
Mind you I keep on thinking about @Techno100
It was the bottles that were going to get a little tap to make them fit:rolleyes:
Landy lover
2,296
5,928
Zummerzet
27ft Eurolight
Camping Caravaning now 5'ering 49 years
You might want to consider fitting BP Gaslite 10kg bottles - easily obtainable via Homebase or many garden centres ( Homebase have regular deals @20% off which includes gas) apart from being able to carry 20kg of gas you save a lot in weight as the bottles are fibreglass
wizzer59
Apr 18, 2009
3,569
3,367
Hymer B584, A Class
Not long enough!
Guess you have to have a special reg, and you can only exchange from????
Landy lover
2,296
5,928
Zummerzet
27ft Eurolight
Most larger caravan /camping shops stock them - its the 27mm one - same as used on some others and I believe the Spanish bottles. if you have a bulkhead mounted reg you just need the adaptor to suit. Not out of the way to refill the Gas lites either as you can see the level you are filling to.
Sep 3, 2012
7,554
26,067
Cheshire
C Class Elddis 175
8+ years
My hymer took 1 x 6KG and a 13Kg but there was a slight bow in the bottom flap -I stiffened this up with a thin metal strap behind the plastic, stuck in place with double sided tape ( there is a recess on the inside face)-just to take the bow out slightly and add a bit more strength to the flap and toprevent the plastic flap from breaking -had no issues with securing the door subsequently.
I exchanged an empty 6kg calor for a full 13kg calor at Morrisons southport, for the cost of gas only -no issues but that was some 3 years ago
Emmit
8,034
17,753
Cornwall
Pilote Explorateur
Jan.2014
And, just to add to the choice, in France you can buy/hire an Antargaz lightweight bottle that is very similar in dimensions to the BP Lite bottle.
The difference of course is in the price of the gas.:):):)
Something to think about if you don't want to go down the refillable route and spend time in France. You could have one of each.
wizzer59
Apr 18, 2009
3,569
3,367
Hymer B584, A Class
Not long enough!
Just a little update for anyone interested, I now have two 11kg Flogas refillers that fit perfectly and they are a lot cheaper to refill than Calor(y)
