Frankia A-750 Tag (1 Viewer)
M
Mitch
Hi all, I've just bought a 1996 Frankia A-750 Tag, Alko chassis I believe.
Here's the thing, I have no manual and the tyre pressure sticker is in Italian/German.
Can anyone tell me what pressure's I should ne running, fully loaded ?
Tyres are 195 / 75 / 15
Cheers, Mitch:Smile:
Kon tiki
487
North Wales
Low Line
You could either try contactiong Frankia or get in touch with the tyre manufacturer. If you have the axle weights from the plate usually under the bonnet they can tell you what pressures you should have.
You say there is a tyre pressure sticker in Italian/German can you put the info on here or take a picture of it & maybe I can help. Is the pressure in 'bar' if it is then 1 bar = 14.5037738 pounds per square inch. You can put it in Google to find out what it is i.e. enter '4.3bar to psi' & you will get the answer
'4.3 bar = 62.3662272 pounds per square inch'
Hope this helps
M
Mitch
Thanks, I'll post a picture.
I'm OK with BAR conversion but the sticker isn't that simple.
Watch this space :Smile:
