Fire Risk from Dometic Fridge
Discussion in 'American RV's' started by Forestboy, Feb 21, 2008.
  1. Forestboy
    Forestboy Funster Life Member
    Jul 31, 2007
    5,039
    8,004
    Forest of Dean
    Reading this months ARV magazine saw this warning.
    For the benefit who have'nt seen it.
    2 Recalls both of which can cause a serious fire
    Cruise Control brake switch on certainFord F53 chasis motorhomes 1995 to 2002
    Apparently more serious some vehicles have been totally destroyed
    Certain Dometic Fridge Models 1998 to 2002
    contact Official Dometic Recall - DometicUSA
    fill in details of your unit and site will advise if action needed.
  2. damondunc
    damondunc Funster
    Aug 2, 2007
    101
    15
    near Lincoln
    You only have to look on some of the american sites about the dometic recall, the 'fix' doesnt actually fix the root cause of the problem it may stop the fridge catching fire, some of these fridges had 354watt heating elements fitted which turned out to be too powerful and under the right(or wrong) conditions may cause the cooling unit to crack in the burner area, all of the later fridges have 325 watt elements fitted, the actual likelyhood of a fire occuring is very unlikely(according to Dometic). Also according to dometic only 0.01% of the fridges with the potential problem actually do have a problem. If the cooling unit does fail it will only catch fire if it is running on gas and the cooling unit develops a large enough crack. The fix consists of fitting various shields and thermal fuses which stop a fire but will not stop the cooling unit cracking. As far as I know the recall is only applicable in North America. I have one to do in april, the owner managed to get the kit from Dometic in america after a fair bit of aggro.
    Dunc.
