Whilst away on holiday last week this happened........................... When I started the engine the step did not automatically retract (it works OK using the button inside the accomodation door). I then noticed that the control panel had not cut out, and finally the fridge was not working on battery...................all these things should happen when the engine is started. I have looked at all the fuses that I know about (there are probably lots more hidden away somewhere). Has anyone got any ideas, please.
On top of that, there is a rumbling coming from (what appears to be) the nearside front wheel...............could this be the start of a wheel bearing going??
The MH is a 2007 Autocruise Starspirit.
Any help or advice would be appreciated (especially on the electrical issue - the rumbling noise Ill peobably get the local dealer to check out, to be on the safe side, as We're on holiday again soon).
Thanks in advance.
Thanks in advance.
