Ducato radiator fans
Discussion in 'Hymer' started by apollomtb, Sep 30, 2011.
  1. apollomtb
    apollomtb Read Only Funster
    Jul 2, 2011
    22
    Stockport
    Here is a newbie question. Just had the coolant replaced on my Hymer (1992 ducato base) and found that only one of the two cooling fans is operational the other is completely seized. Does anyone know where I might seek a replacement?
    Many thanks
  2. aba
    aba Read Only Funster
    Oct 27, 2009
    2,792
    1,117
    yorkshire
    you may be able to get one from a breakers / scrap yard.
    if you can remove the seized one from the housing and take it along with you to said breakers they may have something thats the same size and fixings as most fans have 3 bolts or rivets that hold the motor in the housing.
    however if the plug on the motor is different ask them if they can supply a piece of wire and the plug to match the replacement then its just a case of cutting off your old plug and splicing the new one in to place.
