Buying brake parts for X250's and fitting guides (1 Viewer)
Techno
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
I bought a box (100) of medium latex pre powdered gloves. They're all right hands :LOL:
Techno
Techno
Jul 28, 2010
15,475
20,756
May 2010
This is the assembly grease I used for all contact surfaces and the slide pins.
Special attention the the hub to disc mating surfaces to prevent a re occurance of siezed on discs. They required the application of a blow torch as well as the very large mallet.
Techno
Techno
Jul 28, 2010
15,475
20,756
May 2010
My trusty extending wheel brace managed to undo the calliper to hub bolts (22mm)
I don't have tightening torque for rear but as it's as a big a thread as the fronts I retightened to 210nm
Techno
Techno
Jul 28, 2010
15,475
20,756
May 2010
Removal of the top hat discs also requires the handbrake shoe adjusters to be backed right off with a flat blade screwdriver through a bolt hole otherwise they'll catch on the wear ridge of the old disc
Techno
Techno
Jul 28, 2010
15,475
20,756
May 2010
If only changing pads there's no need to remove anything more than one slide pin bolt , the one furthest from the brake hose and the calliper will pivot clear to do the rest.
Techno
Techno
Jul 28, 2010
15,475
20,756
May 2010
If you don't have a caliper piston push back tool you can improvise by replacing the caliper with pads removed and levering against the back of the disc. Give the rubber boot a good clean first.
I'd only do this if fitting new discs
Techno
Techno
Jul 28, 2010
15,475
20,756
May 2010
Got to service Jacs car tomorrow and take it for two tyres (Costco) , lots of tread but very cracked.
Weather is wonderful yes? probably do front brakes Friday
Techno
Techno
Jul 28, 2010
15,475
20,756
May 2010
First crack the wheel nuts and turn the wheel outwards
Lift the vehicle, secure and then remove the wheel
One wheel will have the pad wear sensor so disconnect this
Remove the caliper slide pin covers
6mm allen key will remove the pins
Remove the caliper and support so not to strain the flex hose
Remove the pads
Continued ......................
Techno
Techno
Jul 28, 2010
15,475
20,756
May 2010
Now you can use a caliper piston push back tool or as I do refit the caliper without pads and use the upper and lower slots to lever them back. If the van has an unknown service record you should remove the master cylinder cap and check that there isn't excess fluid. If needed use a piece of kitchen towel to soak some up.
pistons retracted
Use an extending or long bar to crack the pad holder bolts (M14 hexagon)
finish off with a ratchet
remove the wheel rim guide pins
Thump the disc both sides until it pops loose
Clean the hub face and prepare with copper slip (avoid getting any in the threads)
Thoroughly degrease and fit new disc, replace guide pins.
Clean loose rust from pad holder grease and fit new anti rattle clips
Refit and torque. 210nm seems about right
Fit new pads
Refit caliper etc and pump brake pedal to take up the slack
Wash hands make a cuppa.
nekarsulm
25
11
Cavan, Ireland
Autoroller -5.Fiat Ducato
ten years
Great write up!
Is it just me, or do those front disks look almost unworn? Did you measure the thickness difference between them and the new ones?
Cheers.
Techno
Techno
Jul 28, 2010
15,475
20,756
May 2010
They've lost about 2mm per side and rust flakes have been coming off the inner face causing a grating noise after long descents
For £100 for the front with pads is it even worth thinking about and also eliminates any bedding in
I've now done what works every time. Depart from buycarpart website and ignore until you get the 5% discount email :LOL:
So I've now got all the parts for under £100 inc delivery from Germany :)
EDIT. you do of course have to register and put them in the basket first! then close the web page
I wonder what a garage would have charged me for the parts alone :eek:
nekarsulm
25
11
Cavan, Ireland
ten years
Fair point. Caliper probably not sliding properly causing the piston side to do more of the braking effort.
Always nice when a job goes smoothly, and the Allen key bolt head doesn't round off ..... :D
Bart
3,188
1,398
Northern Ireland
Boxer L4H2 van build
Since 2016
Nice Tutorial Andy let us know how the brake pads / discs perform after you've have a chance to do a few hundred miles with them fitted , as that was a good price. :)
Bart
3,188
1,398
Northern Ireland
Since 2016
so you are happy with them then , ill bookmark that supplier for future.
Techno
Techno
Jul 28, 2010
15,475
20,756
May 2010
Quality German made discs and Italian pads what's not to like
Expect a weak £ to push prices up tho
5,453
10,183
Birmingham, UK
A-Class
Just resurrecting an old thread to say thanks to Techno for the guide. I bought a new set of Brembo discs (coated, so they shouldn't rust) and Brembo pads (with replacement hardware) for ~£120 from AutoPartsPro.co.uk for the front of my 2007 Ducato x250. Note that AutoPartsPro is German, so stuff takes about a week to arrive.
I only attempt light mechanical work and I've never done anything with with the brakes before. It took about 3 hours total, including a couple of breaks for the pee'ing rain. Even though everything looked like it was going to be a rusty nightmare, it was pretty simple. I took it for a tentative test drive. The first heavy braking test from 40mph, the pads felt like they were ice. After that it was fine. The garage quoted £300, so saved a good chunk of cash.
43,329
49,444
What do you mean by 'coated'?
You do know they have a thin coating of protective sticky grease to prevent rusting in storage and that needs thoroughly cleaning off with brake cleaner/degrease.
joka250
907
1,554
Fylde Coast.
Since 1985
Which is why the first use felt like ice.
2x2camper
851
2,006
Sep 17, 2017
5,453
10,183
Birmingham, UK
A-Class
The coating covers the whole disc to prevent the mild steel from rusting. I'm pretty sure that it's worn off the braking surfaces straight away, but it should keep the rest a bit less scraggy...
I did thoroughly brake clean everything and keep changing my gloves to reduce the chance i got greases on the pads or surfaces. I wasn't sure if the lack of friction on the first hard brake was due to the surface coating wearing off, or just normal bedding in.
Deneb
1,598
2,334
Europe
PVC
They need to bed in. Perfectly normal for the feel to be poor initially when new pads are fitted. You should also avoid hard or heavy braking for the first 100 miles or so to allow them to bed in gradually, which avoids the possibility of grabbing or judder due to uneven transfer of the friction material between the pads and disc.
