Hi, I have recently taken the plunge and bought a 1990 Swift Kon-tiki on a Fiat Ducato 2.5 non turbo. As I try to familarise myself I have a few questions if anyone can help? 1. I want to fit new glow plugs but cannot figure how to remove the 4th plug ( Extreme left as looking at the engine). 2. There are 2 waste tanks, the one which discharges from the passengers side only seems to be piped to connect to the sink drainer. All other outlets to the rear tank, is this correct? 3. The gear stick has been welded at some point, it works fine and gear change is good, should I be concerned that it might break again? any spares out there? 4. Lastly I read that the rear axle need regular greasing. There appears to be grease around the nipples so that is promising!! However I am confused as to whether both sides have to be lifted together or if you can raise one and grease and then repeat on other side. While on this, is it acceptable to use a quality general grease as the recommended ones are proving difficult to obtain. Appreciate any advice there might be out there. TMark
